系统管理指南:名称和目录服务(DNS、NIS 和 LDAP)
named.conf 选项
以下列表比较了 BIND 8 和 BIND 9 的 named.conf 选项。还提供了更改的简短说明。“更改”列中的 OK 表示选项在 BIND 9 版本的 named 中工作方式不变。
选项 {
更改
[ version version_string; ]
OK
[ directory path_name; ]
OK
[ named-xfer path_name; ]
过时 [由于体系结构差别而过时。]
[ dump-file path_name; ]
OK
[ memstatistics-file path_name; ]
未实现
[ pid-file path_name; ]
OK
[ statistics-file path_name; ]
OK
[ auth-nxdomain yes_or_no; ]
OK [BIND 8 中缺省设置为 yes,而 BIND 9 中缺省设置为 no。]
[ dialup yes_or_no;
OK
[ fake-iquery yes_or_no; ]
过时
[ fetch-glue yes_or_no; ]
过时
[ has-old-clients yes_or_no; ]
过时
[ host-statistics yes_or_no; ]
未实现
[ host-statistics-max number; ]
未实现
[ multiple-cnames yes_or_no; ]
过时
[ notify yes_or_no | explicit; ]
OK
[ recursion yes_or_no; ]
OK
[ rfc2308-type1 yes_or_no; ]
未实现
[ use-id-pool yes_or_no; ]
过时
[ treat-cr-as-space yes_or_no; ]
过时
[ also-notify yes_or_no; ]
语法已更改 [选择 yes 时,需要一个 IP 地址。]
[ forward ( only | first ); ]
OK [如果不指定转发器,此选项将不工作;在此情况下,会产生 no matching 'forwarders' statement 错误。]
[ forwarders { [ in_addr ; \
[ in_addr ; ... ] ] }; ]
OK [请参见 [ forward ] 子句。]
[ check-names ( master | slave | \
response ) ( warn | fail | ignore); ]
未实现
[ allow-query { address_match_list }; ]
OK
[ allow-recursion { address_match_list }; ]
OK
[ allow-transfer { address_match_list }; ]
OK
[ blackhole { address_match_list }; ]
OK
[ listen-on [ port ip_port ] \
OK
[ query-source [ address ( ip_addr | * ) ] \
OK
[ port ( ip_port | * ) ] ; ]
[ lame-ttl number; ]
OK
[ max-transfer-time-in number; ]
OK
[ max-ncache-ttl number; ]
OK
[ min-roots number; ]
未实现
[ transfer-format ( one-answer | \
many-answers ); ]
OK [BIND 8 中缺省设置为 one-answer,而 BIND 9 中缺省设置为 many-answers。]
[ transfers-in number; ]
OK
[ transfers-out number; ]
OK
[ transfers-per-ns number; ]
OK
[ transfer-source ip_addr; ]
OK
[ maintain-ixfr-base yes_or_no; ]
过时
[ max-ixfr-log-size number; ]
过时 [不需要此选项,因为 BIND 9 会自动剪裁其日志文件的大小。]
[ coresize size_spec ; ]
OK
[ datasize size_spec ; ]
OK
[ files size_spec ; ]
OK
[ stacksize size_spec ; ]
OK
[ cleaning-interval number; ]
OK
[ heartbeat-interval number; ]
OK
[ interface-interval number; ]
OK
[ statistics-interval number; ]
未实现
[ topology { address_match_list }; ]
未实现
[ sortlist { address_match_list }; ]
OK
[ rrset-order { order_spec ; \
[ order_spec ; ... ] }; ]
未实现
BIND 9 中的语句
本节介绍 BIND 8 语句与 BIND 9 语句之间的所有差别。
Controls 语句
unixndc 的缺省设置,并且编译了所有参数。inetrndc 唯一的选项,并且未编译任何内容。
  Syntax
     controls {
       [ inet ip_addr
         port ip_port
         allow { address_match_list; }; ]	OK
       [ unix path_name
         perm number
         owner number
         group number; ]			Not Implemented
日志语法发生了显著更改。有关 named.conf 选项的列表,请参见named.conf 选项
Zone 语句
BIND 8 named.conf 手册页中用于区域语句的语法大部分在 BIND 9 中都受支持,以下语法除外:
  [ pubkey number number number string; ]	Obsolete
  [ check-names ( warn | fail | ignore ); ]	Not Implemented
ACL 语句
该语句在 BIND 9 中的工作方式未更改。
  Syntax
     acl name {
       address_match_list
Key 语句
  Syntax
     key key_id {
       algorithm algorithm_id;
       secret secret_string;
Trusted-Keys 语句
工作方式未更改,但使用此语句的代码在 BIND 9.2.4 中已被禁用。
  Syntax
     trusted-keys {
       [ domain_name flags protocol algorithm key; ]
Server 语句
support-ixfr 已过时,但以下所有选项在 BIND 9 中的工作方式未更改。请注意,transfer-format 的缺省设置已更改。
  Syntax
     server ip_addr {
       [ bogus yes_or_no; ]
       [ transfers number; ]
       [ transfer-format ( one-answer | many-answers ); ]
       [ keys { key_id [ key_id ... ] }; ]
       [ edns yes_or_no; ]
Include 语句
  Syntax
     include path_name;
named.conf 选项摘要
BIND 9.2.4 不包括详细的 named.conf 手册页。下面是 BIND 9.2.4 支持的 named.conf 选项的摘要。
options  {
        blackhole { <address_match_element>; ... };
        coresize <size>;
        datasize <size>;
        deallocate-on-exit <boolean>; // obsolete
        directory <quoted_string>;
        dump-file <quoted_string>;
        fake-iquery <boolean>; // obsolete
        files <size>;
        has-old-clients <boolean>; // obsolete
        heartbeat-interval <integer>;
        host-statistics <boolean>; // not implemented
        host-statistics-max <integer>; // not implemented
        interface-interval <integer>;
        listen-on [ port <integer> ] { <address_match_element>; ... };
        listen-on-v6 [ port <integer> ] { <address_match_element>; ... };
        match-mapped-addresses <boolean>;
        memstatistics-file <quoted_string>; // not implemented
        multiple-cnames <boolean>; // obsolete
        named-xfer <quoted_string>; // obsolete
        pid-file <quoted_string>;
        port <integer>;
        random-device <quoted_string>;
        recursive-clients <integer>;
        rrset-order { [ class <string> ] [ type <string> ] [ name
            <quoted_string> ] <string> <string>; ... }; // not implemented
        serial-queries <integer>; // obsolete
        serial-query-rate <integer>;
        stacksize <size>;
        statistics-interval <integer>; // not yet implemented
        tcp-clients <integer>;
        tkey-dhkey <quoted_string> <integer>;
        tkey-gssapi-credential <quoted_string>;
        tkey-domain <quoted_string>;
        transfers-per-ns <integer>;
        transfers-in <integer>;
        transfers-out <integer>;
        treat-cr-as-space <boolean>; // obsolete
        use-id-pool <boolean>; // obsolete
        use-ixfr <boolean>;
        version <quoted_string>;
        allow-recursion { <address_match_element>; ... };
        allow-v6-synthesis { <address_match_element>; ... };
        sortlist { <address_match_element>; ... };
        topology { <address_match_element>; ... }; // not implemented
        auth-nxdomain <boolean>; // default changed
        minimal-responses <boolean>;
        recursion <boolean>;
        provide-ixfr <boolean>;
        request-ixfr <boolean>;
        fetch-glue <boolean>; // obsolete
        rfc2308-type1 <boolean>; // not yet implemented
        additional-from-auth <boolean>;
        additional-from-cache <boolean>;
        query-source <querysource4>;
        query-source-v6 <querysource6>;
        cleaning-interval <integer>;
        min-roots <integer>; // not implemented
        lame-ttl <integer>;
        max-ncache-ttl <integer>;
        max-cache-ttl <integer>;
        transfer-format ( many-answers | one-answer );
        max-cache-size <size_no_default>;
        check-names <string> <string>; // not implemented
        cache-file <quoted_string>;
        allow-query { <address_match_element>; ... };
        allow-transfer { <address_match_element>; ... };
        allow-update-forwarding { <address_match_element>; ... };
        allow-notify { <address_match_element>; ... };
        notify <notifytype>;
        notify-source ( <ipv4_address> | * ) [ port ( <integer> | * ) ];
        notify-source-v6 ( <ipv6_address> | * ) [ port ( <integer> | * ) ];
        also-notify [ port <integer> ] { ( <ipv4_address> | <ipv6_address>
            ) [ port <integer> ]; ... };
        dialup <dialuptype>;
        forward ( first | only );
        forwarders [ port <integer> ] { ( <ipv4_address> | <ipv6_address> )
        maintain-ixfr-base <boolean>; // obsolete
        max-ixfr-log-size <size>; // obsolete
        transfer-source ( <ipv4_address> | * ) [ port ( <integer> | * ) ];
        transfer-source-v6 ( <ipv6_address> | * ) [ port ( <integer> | * ) ];
        max-transfer-time-in <integer>;
        max-transfer-time-out <integer>;
        max-transfer-idle-in <integer>;
        max-transfer-idle-out <integer>;
        max-retry-time <integer>;
        min-retry-time <integer>;
        max-refresh-time <integer>;
        min-refresh-time <integer>;
        sig-validity-interval <integer>;
        zone-statistics <boolean>;
controls {
        inet ( <ipv4_address> | <ipv6_address> | * ) [ port ( <integer> | *
            ) ] allow { <address_match_element>; ... } [ keys { <string>; ... } ];
        unix <unsupported>; // not implemented
acl <string> { <address_match_element>; ... };
logging {
        channel <string> {
                file <logfile>;
                syslog <optional_facility>;
                null;
                stderr;
                severity <logseverity>;
                print-time <boolean>;
                print-severity <boolean>;
                print-category <boolean>;
        category <string> { <string>; ... };
view <string> <optional_class> {
        match-clients { <address_match_element>; ... };
        match-destinations { <address_match_element>; ... };
        match-recursive-only <boolean>;
        key <string> {
                algorithm <string>;
                secret <string>;
        zone <string> <optional_class> {
                type ( master | slave | stub | hint | forward );
                allow-update { <address_match_element>; ... };
                ixfr-base <quoted_string>; // obsolete
                ixfr-tmp-file <quoted_string>; // obsolete
                masters [ port <integer> ] { ( <ipv4_address> |
                    <ipv6_address> ) [ port <integer> ] [ key <string> ]; ... };
                pubkey <integer> <integer> <integer> <quoted_string>; //
                    obsolete
                update-policy { ( grant | deny ) <string> ( name |
                    subdomain | wildcard | self ) <string> <rrtypelist>; ... };
                database <string>;
                check-names <string>; // not implemented
                    <ipv6_address> ) [ port <integer> ]; ... };
                    <integer> | * ) ];
        server {
                bogus <boolean>;
                support-ixfr <boolean>; // obsolete
                transfers <integer>;
                keys <server_key>;
                edns <boolean>;
        trusted-keys { <string> <integer> <integer> <integer>
            <quoted_string>; ... };
        lame-ttl <integer>;
lwres {
        listen-on [ port <integer> ] { ( <ipv4_address> | <ipv6_address> )
        view <string> <optional_class>;
        search { <string>; ... };
        ndots <integer>;
key <string> {
        algorithm <string>;
        secret <string>;
        masters [ port <integer> ] { ( <ipv4_address> | <ipv6_address> ) [
        pubkey <integer> <integer> <integer> <quoted_string>; // obsolete
        update-policy { ( grant | deny ) <string> ( name | subdomain |
        database <string>;
server {
        bogus <boolean>;
        keys <server_key>;
        edns <boolean>;
trusted-keys { <string> <integer> <integer> <integer> <quoted_string>; ... };
