系统管理指南:名称和目录服务(DNS、NIS 和 LDAP)
第 9 章 LDAP 的基本组件和概念(概述)
本章包含以下主题:
LDAP 数据交换格式 (LDAP Data Interchange Format, LDIF)
LDIF 是一种基于文本的格式,用于描述目录服务实体及其属性。使用 LDIF 格式,可以借助 ldapaddldapmodify 等命令将信息从一个目录移到另一个目录。下面是每个服务的 LDIF 格式示例。使用带有 -l 选项的 ldaplist(1) 可以显示以下信息:
% ldaplist -l hosts myhost
hosts
dn: cn=myhost+ipHostNumber=7.7.7.115,ou=Hosts,dc=mydc,dc=mycom,dc=com
cn: myhost
iphostnumber: 7.7.7.115
objectclass: top
objectclass: device
objectclass: ipHost
description: host 1 - floor 1 - Lab a - building b
% ldaplist -l passwd user1
passwd
dn: uid=user1,ou=People,dc=mydc,dc=mycom,dc=com
uid: user1
cn: user1
userpassword: {crypt}duTx91g7PoNzE
uidnumber: 199995
gidnumber: 20
gecos: Joe Smith [New York]
homedirectory: /home/user1
loginshell: /bin/csh
objectclass: top
objectclass: shadowAccount
objectclass: account
objectclass: posixAccount
% ldaplist -l services name
services
dn: cn=name+ipServiceProtocol=udp,ou=Services,dc=mydc,dc=mycom,dc=com
cn: name
cn: nameserver
ipserviceprotocol: udp
ipserviceport: 42
objectclass: top
objectclass: ipService
% ldaplist -l group mygroup
group
dn: cn=mygroup,ou=Group,dc=mydc,dc=mycom,dc=com
cn: mygroup
gidnumber: 4441
memberuid: user1
memberuid: user2
memberuid: user3
objectclass: top
objectclass: posixGroup
% ldaplist -lnetgroup mynetgroup
netgroup
cn=mynetgroup,ou=netgroup,dc=central,dc=sun,dc=com
objectclass=nisNetgroup
objectclass=top
cn=mynetgroup
nisnetgrouptriple=(user1..mydc.mycom.com,-,)
nisnetgrouptriple=(user1.,-,)
membernisnetgroup=mylab
% ldaplist -l networks 200.20.20.0
networks
dn: ipNetworkNumber=200.20.20.0,ou=Networks,dc=mydc,dc=mycom,dc=com
cn: mynet-200-20-20
ipnetworknumber: 200.20.20.0
objectclass: top
objectclass: ipNetwork
description: my Lab Network
ipnetmasknumber: 255.255.255.0
% ldaplist -l netmasks 201.20.20.0
netmasks
dn: ipNetworkNumber=201.20.20.0,ou=Networks,dc=mydc,dc=mycom,dc=com
cn: net-201
ipnetworknumber: 201.20.20.0
objectclass: top
description: my net 201
% ldaplist -l rpc ypserv
rpc
dn: cn=ypserv,ou=Rpc,dc=mydc,dc=mycom,dc=com
cn: ypserv
cn: ypprog
oncrpcnumber: 100004
objectclass: top
objectclass: oncRpc
% ldaplist -l protocols tcp
protocols
dn: cn=tcp,ou=Protocols,dc=mydc,dc=mycom,dc=com
cn: tcp
ipprotocolnumber: 6
description: transmission control protocol
objectclass: top
objectclass: ipProtocol
% ldaplist -l bootparams myhost
bootparams
dn: cn=myhost,ou=Ethers,dc=mydc,dc=mycom,dc=com
bootparameter: root=boothost:/export/a/b/c/d/e
objectclass: top
objectclass: device
objectclass: bootableDevice
cn: myhost
% ldaplist -l ethers myhost
ethers
macaddress: 8:1:21:71:31:c1
objectclass: top
objectclass: device
objectclass: ieee802Device
cn: myhost
% ldaplist -l publickey myhost
publickey
dn: cn=myhost+ipHostNumber=200.20.20.99,ou=Hosts,dc=mydc,dc=mycom,dc=com
cn: myhost
iphostnumber: 200.20.20.99
description: Joe Smith
nispublickey: 9cc01614d929848849add28d090acdaa1c78270aeec969c9
nissecretkey: 9999999998769c999c39e7a6ed4e7afd687d4b99908b4de99
objectclass: top
objectclass: NisKeyObject
objectclass: device
objectclass: ipHost
% ldaplist -l aliases myname
aliases
dn: mail=myname,ou=aliases,dc=mydc,dc=mycom,dc=com
cn: myname
mail: myname
objectclass: top
objectclass: mailgroup
mgrprfc822mailmember: my.name
LDAP 使用全限定域名
与 NIS 或 NIS+ 客户机不同,LDAP 客户机总是 返回主机名的全限定域名 (fully qualified domain name, FQDN)。LDAP FQDN 与 DNS 返回的 FQDN 相似。例如,假设域名为以下形式:
west.example.net
查找主机名 server 时,gethostbyname()getnameinfo() 都将返回 FQDN 版本。
server.west.example.net
此外,如果使用特定于接口的别名(例如 server-#),则将返回一个较长的全限定主机名列表。 如果要使用主机名共享文件系统或者进行类似的其他检查,则必须对这些检查进行说明。例如,如果将非 FQDN 用于本地主机,FQDN 仅用于由 DNS 解析的远程主机,则必须说明二者之间的区别。如果使用与 DNS 不同的域名设置 LDAP,则同一个主机可能会以两个不同的 FQDN 结尾,具体情况取决于查找源。
缺省目录信息树 (Directory Information Tree, DIT)
缺省情况下,Solaris LDAP 客户机在访问信息时假设 DIT 具有给定的结构。对于 LDAP 服务器支持的每个域,都存在一个具有假定结构的子树。不过,通过指定服务搜索描述符 (Service Search Descriptor, SSD) 可以覆盖缺省结构。对于给定域,缺省 DIT 将具有一个用于存放许多已知容器的基本容器,这些已知容器用于存储特定信息类型的项。有关这些子树的名称,请参见下表。(此信息可在 RFC 2307 和其他参考资料中找到。)
表 9–1 DIT 缺省位置
缺省容器
信息类型
ou=Ethers
bootparams(4)、ethers(4)
ou=Group
group(4)
ou=Hosts
hosts(4)、ipnodes(4) 和主机的 publickey
ou=Aliases
aliases(4)
ou=Netgroup
netgroup(4)
ou=Networks
networks(4)、netmasks(4)
ou=People
passwd(1)、shadow(4)、user_attr(4)、audit_user(4) 和用户的 publickey
ou=printers
printers(4)
ou=Protocols
protocols(4)
ou=Rpc
rpc(4)
ou=Services
services(4)
ou=SolarisAuthAttr
auth_attr(4)
ou=SolarisProfAttr
prof_attr(4)、exec_attr(4)
ou=projects
project
automountMap=auto_*
auto_*
缺省 LDAP 架构
架构是用于描述可作为项存储在 LDAP 目录中的信息类型的定义。要支持 LDAP 名称客户机,可能需要扩展目录服务器的架构。第 14 章,LDAP 一般参考(参考)中提供了有关 IETF 和 Solaris 特定架构的详细消息。还可以从 IETF Web 站点 http://www.ietf.org 访问各种 RFC。
服务搜索描述符 (Service Search Descriptor, SSD) 和架构映射
注意 –
使用架构映射时一定要谨慎,而且必须采用一致的方式。应确保所映射属性的语法与其映射到的属性的语法一致。换而言之,应确保单值属性映射到单值属性,属性的语法保持一致,并且映射对象类应该具有正确的强制性属性(可能是映射属性)。
如上所述,缺省情况下,LDAP 名称服务要求以特定方式构造 DIT。如果需要,可以指示 Solaris LDAP 名称服务在 DIT 的非缺省位置中进行搜索。另外,还可以指定用不同的属性和对象类来代替缺省架构所指定的属性和对象类。有关缺省过滤器的列表,请参见LDAP 名称服务使用的缺省过滤器
SSD 说明
serviceSearchDescriptor 属性 定义 LDAP 名称服务客户机搜索特定服务信息的方式和位置。serviceSearchDescriptor 包含一个服务名称,其后跟一个或多个用分号分隔的基 (base)-范围 (scope) -过滤器 (filter) 三元参数。 使用这些基 (base)-范围 (scope) -过滤器 (filter) 三元参数,可以定义仅搜索特定服务并按顺序进行搜索。 如果针对给定服务指定了多个基 (base)-范围 (scope) -过滤器 (filter),则该服务查找特定项时,将使用指定的范围和过滤器在每个基本容器中进行搜索。
注意 –
使用 SSD 时,不会在缺省位置中搜索服务(数据库),除非该 SSD 中包括缺省位置。 如果针对某个服务指定了多个 SSD,将会产生不可预测的行为。
在以下示例中,Solaris LDAP 名称服务客户机会依次在 ou=west,dc=example,dc=comou=east,dc=example,dc=com 中执行一级搜索,以查找 passwd 服务。要查找用户 usernamepasswd 数据,可以针对每个 BaseDN 使用缺省的 LDAP 过滤器 (&(objectClass=posixAccount)(uid=username))
serviceSearchDescriptor: passwd:ou=west,dc=example,dc=com;ou=east,
dc=example,dc=com
在以下示例中,Solaris LDAP 名称服务客户机将在 ou=west,dc=example,dc=com 中执行子树搜索以查找 passwd 服务。要查找用户 usernamepasswd 数据,可以使用 LDAP 过滤器 (&(fulltimeEmployee=TRUE)(uid=username)) 搜索 ou=west,dc=example,dc=com 子树。
dc=com?sub?fulltimeEmployee=TRUE
还可以将多个容器与一个特定的服务类型关联。在以下示例中,服务搜索描述符指定在三个容器中搜索口令项。
请注意,在下面的示例中,SSD 中的结尾 ',' 表示 defaultSearchBase 将附加在相对基本容器之后。
defaultSearchBase: dc=example,dc=com
serviceSearchDescriptor: \
passwd:ou=myuser,;ou=newuser,;ou=extuser,dc=example,dc=com
属性映射
使用 Solaris LDAP 名称服务时, 可以重新映射其任何服务的一个或多个属性名。(Solaris LDAP 客户机使用第 14 章,LDAP 一般参考(参考)中列出的已知属性。) 如果映射一个属性,则必须确保该属性与初始属性具有相同的含义和语法。请注意,映射 userPassword 属性可能会产生问题。
出于多种原因,您可能需要使用架构映射。
此属性的格式为 service:attribute-name=mapped-attribute-name
如果要针对给定服务映射多个属性,则可以定义多个 attributeMap 属性。
在以下示例中,将 uidhomeDirectory 属性用于 passwd 服务时便会使用 employeeNamehome 属性。
attributeMap: passwd:uid=employeeName
attributeMap: passwd:homeDirectory=home
但也会出现以下特殊情况:将 passwd 服务的 gecos 属性映射到多个属性。下面是一个示例:
attributemap: gecos=cn sn title
以上示例将 gecos 值映射到用空格分隔的 cnsntitle 属性值的列表。
对象类映射
使用 Solaris LDAP 名称服务时, 可以重新映射其任何服务的对象类。如果要针对给定服务映射多个对象类,则可以定义多个 objectclassMap 属性。在以下示例中,使用 posixAccount 对象类时便会使用 myUnixAccount 对象类。
objectclassMap: passwd:posixAccount=myUnixAccount
LDAP 客户机配置文件
为了简化 Solaris 客户机设置,并避免针对每台客户机都重新输入同样的信息,可以在目录服务器上创建一个客户机配置文件。这样,通过一个配置文件便可以为所有配置为使用该配置文件的客户机定义配置。以后对配置文件属性进行的任何更改都会按刷新间隔所定义的频率传播到客户机。
这些客户机配置文件应存储在 LDAP 服务器上的已知位置中。给定域的根 DN 必须具有对象类 nisDomainObject 以及包含客户机所在域的 nisDomain 属性。 所有的配置文件都位于相对于此容器的 ou=profile 容器中。这些配置文件应可以匿名读取。
客户机的配置文件属性
下表列出了 Solaris LDAP 客户机的配置文件属性,这些属性可以在运行 idsconfig 时自动设置。有关如何手动设置客户机配置文件的信息,请参见手动初始化客户机以及 idsconfig (1M) 手册页。
表 9–2 客户机的配置文件属性
属性
说明
cn
配置文件的名称。该属性没有缺省值。必须指定该属性值。
preferredServerList
首选服务器的主机地址是用空格分隔的服务器地址的列表。(请勿使用主机名。) 将先尝试与该列表中的服务器建立连接,然后再尝试与 defaultServerList 中的服务器建立连接,直到成功建立连接。该属性没有缺省值。在 preferredServerListdefaultServerList 中至少必须指定一台服务器。
defaultServerList
缺省服务器的主机地址是用空格分隔的服务器地址的列表。(请勿使用主机名。)在尝试与 preferredServerlist 中的服务器建立连接之后,会先尝试与客户机所在子网中的缺省服务器建立连接,然后再尝试与其余的缺省服务器建立连接,直到成功建立连接。在 preferredServerListdefaultServerList 中至少必须指定一台服务器。只有在尝试与首选服务器列表中的服务器建立连接之后,才会尝试与该列表中的服务器建立连接。该属性没有缺省值。
defaultSearchBase
相对于要在其中查找已知容器的位置的 DN。该属性没有缺省值。不过,对于给定服务,可以使用 serviceSearchDescriptor 属性覆盖该属性。
defaultSearchScope
定义客户机要搜索的数据库范围。可以使用 serviceSearchDescriptor 属性覆盖该属性。可能的值为 onesub。缺省搜索级别为 one
authenticationMethod
标识客户机使用的验证方法。缺省值为 none(匿名)。有关更多信息,请参见选择验证方法
credentialLevel
标识客户机应该用于验证的凭证类型。选项包括 anonymousproxy。缺省值为 anonymous
定义客户机搜索名称数据库的方式和位置,例如,客户机应在 DIT 中的一个点还是多个点执行查找。缺省情况下,不定义任何 SSD。
serviceAuthenticationMethod
客户机针对指定服务使用的验证方法。缺省情况下,不定义任何服务验证方法。如果某个服务未定义 serviceAuthenticationMethod,则使用 authenticationMethod 的缺省值。
attributeMap
客户机使用的属性映射。缺省情况下,不定义任何 attributeMap
objectclassMap
客户机使用的对象类映射。缺省情况下,不定义任何 objectclassMap
searchTimeLimit
客户机上的搜索操作在超时之前可以执行的最长时间(以秒为单位)。这并不影响在 LDAP 服务器上完成搜索所需的时间。缺省值为 30 秒。
bindTimeLimit
客户机与服务器的绑定在超时之前可以持续的最长时间(以秒为单位)。缺省值为 30 秒。
followReferrals
指定客户机是否应遵循 LDAP 引用。可能的值为 TRUEFALSE。缺省值为 TRUE
profileTTL
ldap_cachemgr (1M) 从 LDAP 服务器刷新客户机配置文件的时间间隔。缺省值为 43200 秒(即 12 小时)。如果指定的值为 0,则不刷新配置文件。
本地客户机属性
下表列出了可以使用 ldapclient 在本地设置的客户机属性。有关更多信息,请参见 ldapclient(1M) 手册页。
表 9–3 本地客户机属性
属性
说明
domainName
指定客户机的域名(该域将成为此客户机的缺省域)。该属性没有缺省值。必须指定该属性值。
proxyDN
代理的标识名。如果使用代理credentialLevel 配置客户机,则必须指定 proxyDN
proxyPassword
代理的口令。如果使用代理的 credentialLevel 配置客户机,则必须定义 proxyPassword
certificatePath
包含证书数据库的本地文件系统中的目录。如果借助 TLS 使用 authenticationMethodserviceAuthenticationMethod 配置客户机,则将使用此属性。缺省值为 /var/ldap
注意 –
如果 SSD 中的 BaseDN 包含一个结尾逗号,则将其视为 defaultSearchBase 的相对值。执行搜索之前,会将 defaultSearchBase 的值附加在 BaseDN 后面。
ldap_cachemgr 守护进程
ldap_cachemgr 是运行于 LDAP 客户机上的守护进程。启动 LDAP 客户机时,系统会调用 ldap_cachemgr 守护进程。该守护进程执行以下主要功能:
注意 –
ldap_cachemgr 必须一直运行,LDAP 名称服务才能正常工作。
有关详细信息,请参阅 ldap_cachemgr(1M) 手册页。
LDAP 名称服务安全模型
简介
Solaris LDAP 名称服务将 LDAP 系统信息库用作名称服务和验证服务的源。本节讨论客户机标识、验证方法、 pam_ldap(5)pam_unix 模块和帐户管理的概念。
注意 –
启用 pam_ldap 帐户管理后,所有用户在每次登录系统时都必须提供口令。进行验证时必须提供登录口令。因此,使用 rshrloginssh等工具进行的不基于口令的登录将会失败。
要访问 LDAP 系统信息库中的信息,客户机首先向目录服务器证明自己的身份。此身份可以是匿名的,也可以是 LDAP 服务器能够识别的对象。基于客户机的身份和服务器的访问控制信息 (access control information, ACI),LDAP 服务器将允许客户机读写目录信息。有关 ACI 的更多信息,请查阅所用 Sun Java System Directory Server 版本的管理指南
如果客户机对于任何给定的请求以非匿名方式进行连接,则客户机必须使用客户机和服务器均支持的验证方法来向服务器证明自己的身份。客户机在证明自己的身份之后即可发出各种 LDAP 请求。
名称服务和验证服务 (pam_ldap) 访问目录的方式有所不同。名称服务基于预定义的身份从目录中读取各项及其属性,验证服务通过使用用户的名称和口令进行登录到 LDAP 服务器的验证,确认用户输入的口令是否正确。 有关验证服务的更多信息,请参见 pam_ldap(5) 手册页。
传输层安全性 (Transport Layer Security, TLS)
注意 –
为了将 TLS 用于 Solaris LDAP 名称服务,目录服务器必须针对 LDAP 和 SSL 分别使用缺省端口 389 和 636。如果目录服务器未使用这些端口,则 TLS 此时便不可用。
TLS 可用于 保护 LDAP 客户机和目录服务器之间的通信安全,提供保密性和数据完整性。TLS 协议是 安全套接字层 (Secure Sockets Layer, SSL) 协议的一个超集。Solaris LDAP 名称服务支持 TLS 连接。请注意,使用 SSL 会增加目录服务器和客户机的负荷。
需要针对 SSL 设置目录服务器。有关针对 SSL 设置 Sun Java System Directory Server 的更多信息,请参阅所用 Sun Java System Directory Server 版本的管理指南。还需要针对 SSL 设置 LDAP 客户机。
如果使用 TLS,则必须安装必要的安全数据库,特别是需要安装证书和密钥数据库文件。例如,如果采用 Netscape Communicator 的旧数据库格式,则需要以下两个文件:cert7.dbkey3.db。或者,如果使用 Mozilla 提供的新数据库格式,则需要三个文件:cert8.dbkey3.dbsecmod.dbcert7.dbcert8.db 文件包含受信任证书。key3.db 文件包含客户机的密钥。即使 LDAP 名称服务客户机不使用客户机密钥,此文件也必须存在。secmod.db 文件包含安全模块,如 PKCS#11 模块。如果使用的是旧格式,则不需要此文件。
有关更多信息,请参见设置 TLS 安全性
指定客户机凭证级别
LDAP 名称服务 客户机根据客户机的凭证级别进行登录到 LDAP 服务器的验证。可以为 LDAP 客户机指定三个可能的凭证级别,LDAP 客户机将使用这些凭证级别进行登录到目录服务器的验证。
Anonymous
如果使用 anonymous 进行访问,则只能访问所有人都能使用的数据。此外,还应考虑安全问题。允许 anonymous 访问目录的某些部分意味着任何具有该目录访问权限的人都具有读取访问权限。如果使用 anonymous 凭证级别,则需要允许对所有的 LDAP 名称项和属性都具有读取访问权限。
注意 – 注意 –
绝对不要对目录进行 anonymous 写入,因为任何人都可以在具有写入访问权限的 DIT 中更改信息,包括其他用户的口令或他们自己的标识。
注意 –
Sun Java System Directory Server 允许基于 IP 地址、DNS 名称、验证方法和时间来限制访问。您可能希望进一步限制访问。有关更多信息,请参阅所用 Sun Java System Directory Server 版本的管理指南中的“管理访问控制”。
Proxy
客户机 使用代理帐户进行登录到目录的验证或绑定到目录。此代理帐户可以是任何允许绑定到目录的项。此代理帐户需要有足够的权限以便在 LDAP 服务器上执行名称服务功能。 需要使用 proxy 凭证级别在每台客户机上配置 proxyDNproxyPassword。经过加密的 proxyPassword 存储在客户机本地。可以为不同组的客户机设置不同的代理。例如,可以为所有的销售客户机配置一个代理,使其可以访问公司范围内可访问的目录和销售目录,同时禁止销售客户机访问包含薪水信息的人力资源目录。或者,在极端情况下,可以为每台客户机指定不同的代理或者为所有客户机仅指定一个代理。典型的 LDAP 部署一般介于这两种极端情况之间。请认真做出选择。代理太少,可能不便于您控制用户对资源的访问。但是,代理太多,又会增加系统设置和维护难度。 您需要根据自己的环境授予代理用户适当的权限。 有关如何确定哪种验证方法最适合您的配置的信息,请参见凭证存储
如果某个代理用户的口令发生变化,则需要在使用此代理用户的每台客户机上更新该口令。如果针对 LDAP 帐户使用口令失效功能,请确保针对代理用户关闭此功能。
注意 –
请注意,代理凭证级别应用于任何给定计算机上所有的用户和进程。如果两个用户需要使用不同的命名策略,则他们必须使用不同的计算机。
另外,如果客户机要使用 proxy 凭证进行验证,则 proxyDN 在所有服务器上都必须具有相同的 proxyPassword
proxy anonymous
proxy anonymous 是一个多值项,其中定义了多个凭证级别。指定了 proxy anonymous 级别的客户机将首先尝试使用其代理标识进行验证。如果客户机由于某种原因(例如,用户锁定、口令过期)而无法作为代理用户进行验证,客户机将使用匿名访问机制。这可能会导致不同级别的服务,具体情况取决于目录的配置方式。
凭证存储
如果将客户机配置为使用 代理标识,则客户机会将其 proxyDNproxyPassword 保存在 /var/ldap/ldap_client_cred 中。为了增强安全性,将仅限超级用户可以访问该文件,并且对 proxyPassword 值进行了加密。尽管以前的 LDAP 实现已将代理凭证存储在客户机的配置文件中,但是 Solaris 9 LDAP 名称服务却未这样做。初始化过程中使用 ldapclient 设置的任何代理凭证都存储在本地。这会提高代理的 DN 和口令信息的安全性。有关设置客户机配置文件的更多信息,请参见第 12 章,设置 LDAP 客户机(任务)
选择验证方法
为客户机指定 proxyproxy-anonymous 凭证级别时,还需要选择代理进行登录到目录服务器的验证的方法。缺省情况下,验证方法是 none,它指示进行匿名访问。对于该验证方法,还存在与之关联的传输安全选项。
与凭证级别一样,验证方法也可以为多值。例如,在客户机配置文件中,可以指定客户机首先尝试使用由 TLS 保护的 simple 方法进行绑定。如果绑定失败,则客户机将尝试使用 sasl/digest-MD5 方法进行绑定。因此,authenticationMethod 可以为 tls:simple;sasl/digest-MD5
LDAP 名称服务支持某些简单身份验证和安全层 (Simple Authentication and Security Layer, SASL) 机制。这些机制无需 TLS 便可安全交换口令。但是,这些机制不提供数据完整性和保密性。有关 SASL 的信息,请参见 RFC 2222。
以下是受支持的验证机制:
注意 – 注意 –
为了使用 digest-MD5,Sun Java System Directory Server 要求以明文形式存储口令。如果将验证方法设置为 sasl/digest-MD5tls:sasl/digest-MD5,则代理用户的口令必须以明文形式存储。应特别小心的是,如果 userPassword 属性以明文形式存储,它将具有正确的 ACI,以便使其不可读。
下表概述了各种验证方法及其各自的特征。
表 9–4 验证方法
绑定
线路上的口令
Sun Java System Directory Server 上的口令
会话
none
否
N/A
N/A
不加密
simple
是
明文
任何
不加密
sasl/digest-MD5
是
加密
明文
不加密
sasl/cram-MD5
是
加密
N/A
不加密
tls:simple
是
加密
任何
加密
tls:sasl/cram-MD5
是
加密
N/A
加密
tls:sasl/digest-MD5
是
加密
明文
加密
验证和服务
可以在 serviceAuthenticationMethod 属性中为给定的服务指定验证方法。目前,以下服务支持此操作:
注意 –
如果未针对服务设置 serviceAuthenticationMethod,则缺省情况下将使用 authenticationMethod 属性的值。
下面示例列出了客户机配置文件的一部分,在这部分客户机配置文件中,用户将使用 sasl/digest-MD5 进行登录到目录服务器的验证,使用 SSL 会话更改其口令。
serviceAuthenticationMethod=pam_ldap:sasl/digest-MD5
serviceAuthenticationMethod=passwd-cmd:tls:simple
可插拔验证方法
使用 PAM 框架,可以在多种验证服务中进行选择。可以将 pam_unixpam_ldap 与 LDAP 结合使用。
建议使用 pam_ldap,因为它的灵活性更强,支持更强大的验证方法并且能够使用帐户管理功能。
pam_unix
如果未对 pam.conf(4) 文件进行过更改,则缺省情况下,pam_unix 功能处于启用状态。
注意 –
Solaris 已经删除了 pam_unix 模块而且将不再支持它。但是,通过一组其他服务模块提供了等效或更强的功能。因此,在本指南中,pam_unix 是指等效的功能,而不是指 pam_unix 模块本身。
下面列出了可提供等效 pam_unix 功能的模块:
pam_unix 遵循传统的 UNIX 验证模型,如下所述。
  1. 客户机从名称服务检索用户的加密口令。
  2. 系统提示用户输入其口令。
  3. 对用户的口令进行加密。
  4. 客户机比较这两个经过加密的口令,确定用户是否通过了验证。
另外,使用 pam_unix 时还存在以下两个限制:
注意 –
pam_unixsasl 验证方法 digest-MD5 不兼容,因为 Sun Java System Directory Server 要求以明文形式存储口令,以便使用 digest-MD5。而 pam_unix 要求以 crypt 格式存储口令。
pam_ldap
实现 pam_ldap 时,用户使用在 pam_ldapserviceAuthenticationMethod 参数(如果存在的话)中定义的验证方法绑定到 LDAP 服务器。否则,将使用 authenticationMethod
如果 pam_ldap 能够使用用户的标识和提供的口令绑定到服务器,它将对用户进行验证。
注意 –
启用 pam_ldap 帐户管理之后,所有用户在每次登录系统时都必须提供口令。进行验证时必须提供登录口令。因此,使用 rshrloginssh 等工具进行的不基于口令的登录将会失败。
pam_ldap 不读取 userPassword 属性。因此,除非其他客户机正在使用 pam_unix,否则无需授予对 userPassword 属性的读取访问权限。此外,pam_ldap 不支持 none 验证方法。因此,您必须定义 serviceAuthenticationMethodauthenticationMethod 属性,以便客户机可以使用 pam_ldap。有关更多信息,请参见 pam_ldap(5) 手册页。
注意 – 注意 –
如果使用 simple 验证方法,则 userPassword 属性在传输过程中可被第三方读取。
请参见pam_ldap 的示例 pam.conf 文件
下表概述了 pam_unixpam_ldap 之间的主要区别。
表 9–5 pam_unixpam_ldap
pam_unix
pam_ldap
口令的发送方式
使用 passwd 服务验证方法
使用 passwd 服务验证方法
新口令的发送方式
加密
不加密(除非使用 TLS)
新口令的存储方式
crypt 格式
Sun Java System Directory Server 中定义的口令存储方案
是否需要读取口令?
是
否
更改口令之后,是否与 sasl/digest-MD5 兼容
否。口令不以 clear 形式存储。用户无法进行验证。
是。只要将缺省的存储方案设置为 clear,用户就可以进行验证。
PAM 和更改口令
可以使用 passwd(1) 更改口令。要更改口令,用户必须对 userPassword 属性具有写入权限。请记住,对于此操作,passwd-cmdserviceAuthenticationMethod 会覆盖 authenticationMethod。在传输过程中可能未对当前的口令进行加密,具体取决于所使用的验证方法。
对于 pam_unix,新的 userPassword 属性在写入 LDAP 之前会使用 UNIX crypt 格式进行加密和标记。因此,无论使用哪种验证方法绑定到服务器,在传输过程中都会对新口令进行加密。有关更多信息,请参见 pam_authtok_store(5) 手册页。
从 Solaris 10 软件发行版开始,pam_ldap 不再支持口令更新。以前建议使用的带有 server_policy 选项的 pam_authtok_store 现已取代pam_ldap 口令更新功能。使用 pam_authtok_store 时,新口令将以明文形式发送到 LDAP 服务器。因此,为了确保保密性,请使用 TLS。如果不使用 TLS,新的 userPassword 很容易被窥探。 如果使用 Sun Java System Directory Server 设置未标记的口令,则该软件会使用 passwordStorageScheme 属性对口令进行加密。有关 passwordStorageScheme 的更多信息,请参见所用 Sun Java System Directory Server 版本的管理指南中有关用户帐户管理的章节。
注意 –
设置 passwordStorageScheme 属性时,需要考虑以下配置问题。如果 NIS、NIS+ 或另一台使用 pam_unix 的客户机将 LDAP 用作系统信息库,则 passwordStorageScheme 必须为 crypt。此外,如果在 Sun Java System Directory Server 上结合使用 pam_ldapsasl/digest-MD5,则必须将 passwordStorageScheme 设置为 clear。
帐户管理
LDAP 名称服务可以利用 Sun Java System Directory Server 中的口令和帐户锁定策略支持。可以将 pam_ldap(5) 配置为支持用户帐户管理。将 passwd(1) 和正确的 PAM 配置结合使用时,将遵循 Sun Java System Directory Server 口令策略所设置的口令语法规则。
通过 pam_ldap(5) 可以支持以下帐户管理功能。这些功能取决于 Sun Java System Directory Server 的口令和帐户锁定策略配置。可以根据需要启用任意功能。
注意 –
前面介绍的帐户管理功能仅适用于 Sun Java System Directory Server。 有关在服务器上配置口令和帐户锁定策略的信息,请参见所用 Sun Java System Directory Server 版本的管理指南中的“用户帐户管理”一章。 另请参见为帐户管理配置的 pam_ldap 的示例 pam_conf 文件。请勿针对 proxy 帐户启用帐户管理。
在 Sun Java System Directory Server 上配置口令和帐户锁定策略之前,请确保所有主机都使用具有 pam_ldap 帐户管理功能的“最新”LDAP 客户机。
另外,还应确保客户机上具有已正确配置的 pam.conf(4) 文件。否则,当 proxy 或用户口令到期后,LDAP 名称服务将无法工作。
注意 –
