系统管理指南:名称和目录服务(DNS、NIS 和 LDAP)
目录用户代理配置文件 (DUAProfile) 架构
DUAConfSchemaOID1.3.6.1.4.1.11.1.3.1
DESC 'Default LDAP server host address used by a DUA'
            EQUALITY caseIgnoreMatch
            SYNTAX 1.3.6.1.4.1.1466.115.121.1.15
            SINGLE-VALUE )
          ( DUAConfSchemaOID.1.1 NAME 'defaultSearchBase'
            DESC 'Default LDAP base DN used by a DUA'
            EQUALITY distinguishedNameMatch
            SYNTAX 1.3.6.1.4.1.1466.115.121.1.12
            SINGLE-VALUE )
          ( DUAConfSchemaOID.1.2 NAME 'preferredServerList'
            DESC 'Preferred LDAP server host addresses to be used by a
            DUA'
            SINGLE-VALUE )
          ( DUAConfSchemaOID.1.3 NAME 'searchTimeLimit'
            DESC 'Maximum time in seconds a DUA should allow for a
            search to complete'
            EQUALITY integerMatch
            SYNTAX 1.3.6.1.4.1.1466.115.121.1.27
            SINGLE-VALUE )
          ( DUAConfSchemaOID.1.4 NAME 'bindTimeLimit'
            DESC 'Maximum time in seconds a DUA should allow for the
            bind operation to complete'
            SINGLE-VALUE )
          ( DUAConfSchemaOID.1.5 NAME 'followReferrals'
            DESC 'Tells DUA if it should follow referrals
            returned by a DSA search result'
            EQUALITY caseIgnoreIA5Match
            SYNTAX 1.3.6.1.4.1.1466.115.121.1.7
            SINGLE-VALUE )
          ( DUAConfSchemaOID.1.6 NAME 'authenticationMethod'
            DESC 'A keystring which identifies the type of
            authentication method used to contact the DSA'
            SINGLE-VALUE )
          ( DUAConfSchemaOID.1.7 NAME 'profileTTL'
            DESC 'Time to live, in seconds, before a client DUA
            should re-read this configuration profile'
				'serviceSearchDescriptor'
            DESC 'LDAP search descriptor list used by a DUA'
            EQUALITY caseExactMatch
            SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 )
          ( DUAConfSchemaOID.1.9 NAME 'attributeMap'
            DESC 'Attribute mappings used by a DUA'
            SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 )
          ( DUAConfSchemaOID.1.10 NAME 'credentialLevel'
            DESC 'Identifies type of credentials a DUA should
            use when binding to the LDAP server'
            SINGLE-VALUE )
          ( DUAConfSchemaOID.1.11 NAME 'objectclassMap'
            DESC 'Objectclass mappings used by a DUA'
          ( DUAConfSchemaOID.1.12 NAME 'defaultSearchScope' SINGLE-VALUE )
          ( DUAConfSchemaOID.1.13 NAME 'serviceCredentialLevel'
            should use when binding to the LDAP server for a
            specific service'
          ( DUAConfSchemaOID.1.15 NAME 'serviceAuthenticationMethod'
            DESC 'Authentication Method used by a service of the DUA'
			  ( DUAConfSchemaOID.2.4 NAME 'DUAConfigProfile'
			  	 SUP top STRUCTURAL
				 DESC 'Abstraction of a base configuration for a DUA'
				 MUST ( cn )
				 MAY ( defaultServerList $ preferredServerList $
                defaultSearchBase $ defaultSearchScope $
                searchTimeLimit $ bindTimeLimit $
                credentialLevel $ authenticationMethod $
                followReferrals $ serviceSearchDescriptor $
                serviceCredentialLevel $ serviceAuthenticationMethod $
                objectclassMap $ attributeMap $
                profileTTL ) )
