On the system you intend to make the boot server for the subnet, log in and become superuser or assume an equivalent role.
The system must include a local CD-ROM drive or have access to the remote current Solaris release disc images, which are normally on the install server. If you use a naming service, the system should be in the naming service. If you do not use a naming service, you must distribute information about this system by following your site's policies.
Mount the Solaris Software - 1 CD image from the install server.
# mount -F nfs -o ro server_name:path /mnt |
Is the install server name and absolute path to the disc image
Create a directory for the boot image.
# mkdir -p boot_dir_path |
Specifies the directory where the boot software is to be copied
Change to the Tools directory on the Solaris Software - 1 CD image.
# cd /mnt/Solaris_10/Tools |
Copy the boot software to the boot server.
# ./setup_install_server -b boot_dir_path |
Specifies to set up the system as a boot server
The setup_install_server command indicates whether you have enough disk space available for the images. To determine available disk space, use the df -kl command.
Change directories to root (/).
# cd / |
Unmount the installation image.
# umount /mnt |
The following example illustrates how to create a boot server on a subnet. These commands copy the boot software from the Solaris Software for SPARC Platforms - 1 CD image to /export/install/boot on the system's local disk.
# mount -F nfs -o ro crystal:/export/install/boot /mnt # mkdir -p /export/install/boot # cd /mnt/Solaris_10/Tools # ./setup_install_server -b /export/install/boot # cd / # umount /mnt |
In this example, the disc is inserted and automatically mounted before the command. After the command, the disc is removed.
After you set up the boot server, you must add the client as an installation client. For information about how to add client systems to install over the network, see Adding Systems to Be Installed From the Network With a CD Image.
For additional information about the setup_install_server command, see install_scripts(1M).
