Solaris 10 8/07 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Viewing the Configuration of a Boot Environment
Use the lufslist command to list the configuration of a boot environment. The output contains the disk slice (file system), file system type, and file system size for each boot environment mount point.
ProcedureTo View the Configuration of a Boot Environment
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # lufslist -n BE_name
    Specifies the name of the boot environment to view file system specifics
    The following example displays a list.
    Filesystem                fstype       size(Mb) Mounted on
    /dev/dsk/c0t0d0s1         swap           512.11 -
    /dev/dsk/c0t4d0s3         ufs           3738.29 /
    /dev/dsk/c0t4d0s4         ufs            510.24 /opt
    Note –
    For an example of a list that contains non-global zones, see To View the Configuration of a Boot Environment's Non-Global Zone File Systems.
