Solaris 10 8/07 Installation Guide: Solaris Live Upgrade and Upgrade Planning
ProcedureTo Display the Status of All Boot Environments
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # lustatus BE_name
    Specifies the name of the inactive boot environment to view status. If BE_name is omitted, lustatus displays status for all boot environments in the system.
    In this example, the status for all boot environments is displayed.
    # lustatus
    boot environment   Is        Active  Active     Can	    Copy
    Name               Complete  Now	 OnReboot   Delete	 Status
    disk_a_S9           yes       yes     yes        no       -
    disk_b_S10database   yes       no      no         yes      COPYING
    disk_b_S9a          no        no      no         yes      -
    Note –
    You could not perform copy, rename, or upgrade operations on disk_b_S9a because it is not complete, nor on disk_b_S10database because a live upgrade operation is in progress.
