Solaris 10 8/07 Installation Guide: Solaris Live Upgrade and Upgrade Planning
ProcedureTo Add or Change a Description for a Boot Environment Name With Text
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # /usr/sbin/ludesc -n  BE_name 'BE_description'
    Specifies the boot environment name and the new description to be associated with the name
Example 7–5 Adding a Description to a Boot Environment Name With Text
In this example, a boot environment description is added to a boot environment that is named second_disk. The description is text that is enclosed in single quotes.
# /usr/sbin/ludesc -n second_disk 'Solaris 10 8/07 test build'
