Solaris 10 8/07 Installation Guide: Solaris Live Upgrade and Upgrade Planning
ProcedureTo Add or Change a Description for a Boot Environment Name With a File
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # /usr/sbin/ludesc -n BE_name -f file_name
    -n BE_name
    Specifies the boot environment name
    Specifies the file to be associated with a boot environment name
Example 7–6 Adding a Description to a Boot Environment Name With a File
In this example, a boot environment description is added to a boot environment that is named second_disk. The description is contained in a gif file.
# /usr/sbin/ludesc -n second_disk -f rose.gif
