Solaris 10 8/07 Installation Guide: Solaris Live Upgrade and Upgrade Planning
ProcedureTo Determine a Boot Environment Name From a Text Description
The following command returns the name of the boot environment associated with the specified description.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # /usr/sbin/ludesc -A 'BE_description'
    -A 'BE_description'
    Specifies the description to be associated with the boot environment name.
Example 7–7 Determining a Boot Environment Name From a Description
In this example, the name of the boot environment, second_disk, is determined by using the -A option with the description.
# /usr/sbin/ludesc -A  'Solaris 10 8/07 test build'
