Solaris 10 8/07 Installation Guide: Solaris Live Upgrade and Upgrade Planning
ProcedureTo Determine a Boot Environment Description From a Name
This procedure displays the description of the boot environment that is named in the command.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # /usr/sbin/ludesc -n BE_name
    -n BE_name
    Specifies the boot environment name.
Example 7–9 Determining a Boot Environment Description From a Name
In this example, the description is determined by using the -n option with the boot environment name.
# /usr/sbin/ludesc -n  second_disk
Solaris 10 8/07 test build
