Solaris 10 8/07 Installation Guide: Solaris Live Upgrade and Upgrade Planning
File System Types
Solaris Live Upgrade distinguishes between two file system types: critical file systems and shareable. The following table describes these file system types.
File System Type
Description
Examples and More Information
Critical file systems
Critical file systems are required by the Solaris OS. These file systems are separate mount points in the vfstab of the active and inactive boot environments. These file systems are always copied from the source to the inactive boot environment. Critical file systems are sometimes referred to as nonshareable.
Examples are root (/), /usr, /var, or /opt.
Shareable file systems
Shareable file systems are user-defined files such as /export that contain the same mount point in the vfstab in both the active and inactive boot environments. Therefore, updating shared files in the active boot environment also updates data in the inactive boot environment. When you create a new boot environment, shareable file systems are shared by default. But you can specify a destination slice and then the file systems are copied.
/export is an example of a file system that can be shared.
For more detailed information about shareable file systems, see Guidelines for Selecting Slices for Shareable File Systems.
Swap
Swap is a special shareable file system. Like a shareable file system, all swap slices are shared by default. But, if you specify a destination directory for swap, the swap slice is copied.
For procedures about reconfiguring swap, see To Create a Boot Environment and Reconfiguring Swap.
Creating RAID-1 Volumes on File Systems
Solaris Live Upgrade can create a boot environment with RAID-1 volumes (mirrors) on file systems. For an overview, see Creating a Boot Environment With RAID-1 Volume File Systems.
