Solaris 10 8/07 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Checking Status of Volumes
If a mirror or submirror needs maintenance or is busy, components cannot be detached. You should use the metastat command before creating a new boot environment and using the detach keyword. The metastat command checks if the mirror is in the process of resynchronization or if the mirror is in use. For information, see the man page metastat(1M).
