Solaris 10 8/07 Installation Guide: Custom JumpStart and Advanced Installations
Procedurex86: To Check IDE Disk for Bad Blocks
IDE disk drives do not automatically map out bad blocks like other drives supported by Solaris software. Before installing Solaris on an IDE disk, you might want to perform a surface analysis on the disk. To perform surface analysis on an IDE disk, follow this procedure.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Boot to the installation media.
  3. When you are prompted to select an installation type, select option 6, Single user shell.
  4. Start the format(1M) program.
    # format
  5. Specify the IDE disk drive on which you want to perform a surface analysis.
    # cxdy
    Is the controller number
    Is the device number
  6. Determine if you have an fdisk partition.
    • If a Solaris fdisk partition already exists, proceed to Step 7.
    • If a Solaris fdisk partition does not exist, use the fdisk command to create a Solaris partition on the disk.
      format> fdisk
  7. To begin the surface analysis, type:
    format> analyze
  8. Determine the current settings, type:
    analyze> config
  9. (Optional) To change settings, type:
    analyze> setup
  10. To find bad blocks, type:
    analyze> type_of_surface_analysis
    Is read, write, or compare
    If format finds bad blocks, it remaps them.
  11. To exit the analysis, type:
    analyze> quit
  12. Determine if you want to specify blocks to remap.
    • If no, go to Step 13.
    • If yes, type:
      format> repair
  13. To exit the format program, type:
  14. Restart the media in multiuser mode by typing the following command.
    # exit
