Solaris 10 5/08 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Installing Solaris Live Upgrade
You can install the Solaris Live Upgrade packages by using the following:
Be aware that the following patches might need to be installed for the correct operation of Solaris Live Upgrade.
Description
For More Information
Caution: Correct operation of Solaris Live Upgrade requires that a limited set of patch revisions be installed for a particular OS version. Before installing or running Solaris Live Upgrade, you are required to install these patches.
x86 only –
If this set of patches is not installed, Solaris Live Upgrade fails and you might see the following error message. If you don't see the following error message, necessary patches still might not be installed. Always verify that all patches listed on the SunSolve info doc have been installed before attempting to install Solaris Live Upgrade.
ERROR: Cannot find or is not executable:
</sbin/biosdev>.
ERROR: One or more patches required
by Live Upgrade has not been installed.
The patches listed in info doc 72099 are subject to change at any time. These patches potentially fix defects in Solaris Live Upgrade, as well as fix defects in components that Solaris Live Upgrade depends on. If you experience any difficulties with Solaris Live Upgrade, please check and make sure that you have the latest Solaris Live Upgrade patches installed.
Ensure that you have the most recently updated patch list by consulting http://sunsolve.sun.com. Search for the info doc 72099 on the SunSolve web site.
If you are running the Solaris 8 or 9 OS, you might not be able to run the Solaris Live Upgrade installer. These releases do not contain the set of patches needed to run the Java 2 runtime environment. You must have the recommended patch cluster for the Java 2 runtime environment recommended to run the Solaris Live Upgrade installer and install the packages.
To install the Solaris Live Upgrade packages, use the pkgadd command. Or install, for the Java 2 runtime environment, the recommended patch cluster. The patch cluster is available on http://sunsolve.sun.com.
For instructions about installing the Solaris Live Upgrade software, see Installing Solaris Live Upgrade.
Required Packages
If you have problems with Solaris Live Upgrade, you might be missing packages. In the following table, check that your OS has the listed packages , which are required to use Solaris Live Upgrade.
For the Solaris 10 release:
For information about software groups, see Disk Space Recommendations for Software Groups in Solaris 10 5/08 Installation Guide: Planning for Installation and Upgrade.
Table 3–2 Required Packages for Solaris Live Upgrade
Solaris 8 Release
Solaris 9 Release
Solaris 10 Release
SUNWadmap
SUNWadmap
SUNWadmap
SUNWadmc
SUNWadmc
SUNWadmlib-sysid
SUNWlibC
SUNWadmfw
SUNWadmr
SUNWbzip
SUNWlibC
SUNWlibC
SUNWgzip
SUNWgzip
For Solaris 10 3/05 only: SUNWgzip
SUNWj2rt
Note –
The SUNWj2rt package is needed only under the following conditions:
  • When you run the Solaris Live Upgrade installer to add Solaris Live Upgrade packages
  • When you upgrade and use CD media
SUNWj2rt
Note –
SUNWj5rt
Note –
The SUNWj5rt package is needed only under the following conditions:
To check for packages on your system, type the following command.
% pkginfo package_name
