Solaris 10 5/08 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Problems With Setting Up Network Installations
Unknown client “host_name
Cause:
The host_name argument in the add_install_client command is not a host in the naming service.
Solution:
Add the host host_name to the naming service and execute the add_install_client command again.
Error: <system name> does not exist in the NIS ethers map
Add it, and rerun the add_install_client command
Description:
When you run the add_install_client command, the command fails with the above error.
Cause:
The client you are adding to the install server does not exist in the server's /etc/ethers file.
Solution:
Add the needed information to the /etc/ethers file on the install server and run the add_install_client command again.
  1. Become superuser or assume an equivalent role.
  2. On the client, find the ethers address.
    # ifconfig -a grep ethers
    ether 8:0:20:b3:39:1d
  3. On the install server, open the /etc/ethers file in an editor. Add the address to the list.
  4. On the client, run add_install_client again as in this example.
    # ./add_install_client bluegill sun4u
