Solaris 10 10/08 Installation Guide: Network-Based Installations
Create and Validate the rules File
The custom JumpStart programs use the rules file to select the correct installation profile for the wanclient-1 system. Create a text file that is named rules. Then, add keywords and values to this file.
The IP address of the wanclient-1 system is 192.168.198.210, and the netmask is 255.255.255.0. Use the network rule keyword to specify the profile that the custom JumpStart programs should use to install wanclient-1.
network 192.168.198.0 - wanclient_1_prof -
This rules file instructs the custom JumpStart programs to use the wanclient_1_prof to install the current Solaris release software on wanclient-1.
Name this rule file wanclient_rule.
After you create the profile and the rules file, you run the check script to verify that the files are valid.
wanserver-1# ./check -r wanclient_rule
If the check script does not find any errors, the script creates the rules.ok file.
Save the rules.ok file in the /opt/apache/htdocs/flash/ directory.
