Solaris 10 10/08 Installation Guide: Network-Based Installations
Sharing Security and Configuration Information in the /etc/netboot Directory
To install clients on your network, you might want to share security and configuration files among several different clients, or across entire subnets. You can share these files by distributing your configuration information throughout the /etc/netboot/net-ip/client-ID, /etc/netboot/net-ip, and /etc/netboot directories. The wanboot-cgi program searches these directories for the configuration information that best fits the client, and uses that information during the installation.
The wanboot-cgi program searches for client information in the following order.
  1. /etc/netboot/net-ip/client-ID – The wanboot-cgi program first checks for configuration information that is specific to the client machine. If the /etc/netboot/net-ip/client-ID directory contains all the client configuration information, the wanboot-cgi program does not check for configuration information elsewhere in the /etc/netboot directory.
  2. /etc/netboot/net-ip – If all the required information is not located in the /etc/netboot/net-ip/client-ID directory, the wanboot-cgi program then checks for subnet configuration information in the /etc/netboot/net-ip directory.
  3. /etc/netboot – If the remaining information is not located in the /etc/netboot/net-ip directory, the wanboot-cgi program then checks for global configuration information in the /etc/netboot directory.
Figure 11–2 demonstrates how you can set up the /etc/netboot directory to customize your WAN boot installations.
Figure 11–2 Sample /etc/netboot Directory
The context describes the graphic.
The /etc/netboot directory layout in Figure 11–2 enables you to perform the following WAN boot installations.
