Solaris 10 10/08 Installation Guide: Network-Based Installations
OBP Commands
The following table lists the OBP commands that you type at the client ok prompt to perform a WAN boot installation.
Table 15–3 OBP Commands for a WAN Boot Installation
Task and Description
OBP Command
Begin an unattended WAN boot installation.
boot net – install
Begin an interactive WAN boot installation.
boot net –o prompt - install
Begin a WAN boot installation from a local CD.
boot cdrom –F wanboot - install
Install a hashing key before you begin a WAN boot installation.key-value is the hexadecimal value of the hashing key.
set-security-key wanboot-hmac-sha1 key-value
Install an encryption key before you begin a WAN boot installation.
  • key-type is either wanboot-3des or wanboot-aes.
  • key-value is the hexadecimal value of the encryption key.
set-security-key key-type key-value
Verify that key values are set in OBP.
list-security-keys
Set client configuration variables before you begin your WAN boot installation.
  • client-IP is the IP address of the client.
  • router-ip is the IP address of the network router.
  • mask-value is the subnet mask value.
  • client-name is the host name of the client.
  • proxy-ip is the IP address of the network's proxy server.
  • wanbootCGI-path is the path to the wanbootCGI programs on the web server.
setenv network-boot-arguments host-ip=client-IP,router-ip=router-ip,subnet-mask=mask-value,hostname=client-name,http-proxy=proxy-ip,file=wanbootCGI-path
Check the network device alias.
devalias
Set the network device alias, where device-path is the path to the primary network device.
  • To set the alias for the current installation only, type devalias net device-path.
  • To permanently set the alias, type nvvalias net device-path.
