Renaming a boot environment is often useful when you upgrade the boot environment from one Solaris release to another release. For example, following an operating system upgrade, you might rename the boot environment solaris8 to solaris10.
Use the lurename command to change the inactive boot environment's name.
Starting with the Solaris 10 1/06 release, the GRUB menu is automatically updated when you use the Rename menu or lurename command. The updated GRUB menu displays the boot environment's name in the list of boot entries. For more information about the GRUB menu, see Booting Multiple Boot Environments.
To determine the location of the GRUB menu's menu.lst file, see Chapter 13, Managing the Solaris Boot Archives (Tasks), in System Administration Guide: Basic Administration.
Limitation |
For Instructions |
The name must not exceed 30 characters in length. | |
The name can consist only of alphanumeric characters and other ASCII characters that are not special to the UNIX shell. |
See the “Quoting” section of sh(1). |
The name can contain only single-byte, 8-bit characters. | |
The name must be unique on the system. | |
A boot environment must have the status “complete” before you rename it. |
See Displaying the Status of All Boot Environments to determine a boot environment's status. |
You cannot rename a boot environment that has file systems mounted with lumount or mount. |
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Type:
# lurename -e BE_name -n new_name |
Specifies the inactive boot environment name to be changed
Specifies the new name of the inactive boot environment
In this example, second_disk is renamed to third_disk.
# lurename -e second_disk -n third_disk |
