Solaris 10 10/08 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Task Map: Upgrading a Boot Environment
Table 5–1 Task Map: Upgrading With Solaris Live Upgrade
Task
Description
For Instructions
Either upgrade a boot environment or install a Solaris Flash archive.
  • Upgrade the inactive boot environment with an OS image.
  • Install a Solaris Flash archive on an inactive boot environment.
Activate an inactive boot environment.
Makes changes effective and switches the inactive boot environment to active .
Activating a Boot Environment
(optional) Switch back if a failure occurs when activating.
Reactivates to the original boot environment if a failure occurs.
Chapter 6, Failure Recovery: Falling Back to the Original Boot Environment (Tasks)
