Solaris 10 10/08 Installation Guide: Custom JumpStart and Advanced Installations
Create an Install Server
Because the groups need to install Solaris 10 10/08 software from the network, you make server-1 an install server for both groups. You use the setup_install_server(1M) command to copy the images to the server-1 local disk (in the /export/install directory). Copy the images from the either of the following media.
You must copy the image from the disc to an empty directory, in these examples the sparc_10 directory and the x86_10 directory.
Example 7–1 SPARC: Copying the Solaris 10 10/08 CDs
Insert the Solaris Software for SPARC Platforms - 1 CD in the CD-ROM drive that is attached to server-1 and type the following commands:
server-1# mkdir -p /export/install/sparc_10
server-1# cd /CD_mount_point/Solaris_10/Tools
server-1# ./setup_install_server /export/install/sparc_10
Insert the Solaris Software for SPARC Platforms - 2 CD in the CD-ROM drive that is attached to server-1 and type the following commands:
server-1# ./add_to_install_server /export/install/sparc_10
Repeat the previous command for each Solaris Software you want to install.
Insert the first SPARC: Solaris Languages for SPARC Platforms CD in the CD-ROM drive that is attached to server-1 and type the following commands:
Repeat the previous command for each SPARC: Solaris Languages for SPARC Platforms CD.
Example 7–2 x86: Copying the Solaris 10 10/08 CDs
Insert the Solaris Software for x86 Platforms - 1 CD in the CD-ROM drive that is attached to server-1 and type the following commands:
server-1# mkdir -p /export/install/x86_10
server-1# ./setup_install_server /export/install/x86_10
Insert the Solaris Software for x86 Platforms - 2 CD in the CD-ROM drive that is attached to server-1 and type the following commands:
server-1# ./add_to_install_server /export/install/x86_10
Insert the first Solaris Languages for x86 Platforms CD in the CD-ROM drive that is attached to server-1 and type the following commands:
Repeat the previous command for each Solaris Languages for x86 Platforms CD.
Example 7–3 SPARC: Copying the Solaris 10 10/08 DVD
Insert the Solaris Operating System for SPARC Platforms DVD in the DVD-ROM drive that is attached to server-1 and type the following commands:
server-1# cd /DVD_mount_point/Solaris_10/Tools
Example 7–4 x86: Copying the Solaris Operating System for x86 Platforms DVD
Insert the Solaris Operating System for x86 Platforms DVD in the DVD-ROM drive that is attached to server-1 and type the following commands:
