You can create an archive with an initial installation that overwrites all the files on the clone system, or you can create a differential archive that only overwrites the changes that are specified. For an overview of a differential archive, see Planning to Create the Solaris Flash Differential Archive for an Update.
A Solaris Flash archive cannot be properly created when a non-global zone is installed. The Solaris Flash feature is not compatible with the Solaris Zones partitioning technology. If you create a Solaris Flash archive, the resulting archive is not installed properly when the archive is deployed under these conditions:
The archive is created in a non-global zone
The archive is created in a global zone that has non-global zones installed
After you install the master system, create a Solaris Flash archive to use to install other systems.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Boot the master system and run it in as inactive a state as possible.
When possible, run the system in single-user mode. If that is not possible, shut down any applications that you want to archive and any applications that require extensive operating system resources.
You can create a Solaris Flash archive while the master system is running in multiuser mode, single-user mode, or while booted from one of the following:
Solaris Operating System DVD.
Solaris Software - 1 CD.
An image of the Solaris Software. If you are using CD media, the image could include the Solaris Languages CDs if needed.
To create the archive, use the flarcreate command.
# flarcreate -n name options path/filename |
The name that you give the archive. The name you specify is the value of the content_name keyword.
For a description of options, see flar Command.
The path to the directory in which you want to save the archive file. If you do not specify a path, flarcreate saves the archive file in the current directory.
The name of the archive file.
If the archive creation is successful, the flarcreate command returns an exit code of 0.
If the archive creation fails, the flarcreate command returns a nonzero exit code.
Make a copy of the archive and save it. The copy can be used in the future to update a clone system with a differential archive.
File systems can be copied exactly or can be customized by excluding some directories or files. You can achieve the same results by using different options. Use the options that best suit your environment.
The file systems in the following examples have been greatly simplified for clarification. Rather than use file system names such as /var, /usr, or /opt, the master system file structure for these examples is the following:
/aaa/bbb/ccc/ddd /aaa/bbb/fff /aaa/eee /ggg |
Use the flarcreate file-exclusion options with caution. If you exclude some directories, others that you were unaware of might be left in the archive, such as system configuration files. The system would then be inconsistent and the installation would not work. Excluding directories and files is best used with data that can easily be removed without disrupting the system, such as large data files.
In this example, the archive is named archive1. This archive is copied exactly from the master system and then compressed. The archive is an exact duplicate of the master system and is stored in archive1.flar.
# flarcreate -n archive1 -c archive1.flar |
To check the file structure of the archive, type the following.
# flar info -l archive1.flarlost+found export export/home export/home/lost+found var var/sadm var/sadm/install var/sadm/install/admin var/sadm/install/admin/default var/sadm/install/logs var/sadm/install/contents var/sadm/install/.lockfile var/sadm/install/.pkg.lock var/sadm/pkg var/sadm/pkg/SUNWocfd var/sadm/pkg/SUNWocfd/install var/sadm/pkg/SUNWocfd/install/copyright var/sadm/pkg/SUNWocfd/save var/sadm/pkg/SUNWocfd/save/pspool var/sadm/pkg/SUNWocfd/save/pspool/SUNWocfd ..... ..... usr/bin/sparcv7 usr/bin/sparcv7/savecore usr/bin/sparcv7/gcore .... .... usr/lib/diff3prog usr/lib/madv.so.1 usr/lib/mpss.so.1 usr/lib/cpu usr/lib/cpu/sparcv8plus .... .... devices/pseudo/udp6@0:udp6 devices/pseudo/udp@0:udp devices/pseudo/tcp@0:tcp devices/pseudo/iwscn@0:iwscn devices/pseudo/wc@0:wscons devices/pseudo/tcp6@0:tcp6 devices/pseudo/sctp6@0:sctp6 var/fm/fmd/ckpt var/fm/fmd/rsrc kernel/drv/st.conf kernel/drv/st.conf kernel/drv/st.conf kernel/drv/st.conf # |
In this example, some individual files are greater than 4 Gbytes. The default archiving utility, cpio, cannot handle these large files. The -L pax copy method is used to create an archive that contains large individual files. The archive is named archive1. This archive is copied exactly from the master system and then compressed. The archive is an exact duplicate of the master system and is stored in archive1.flar.
# flarcreate -L pax -n archive1 -c archive1.flar |
# flar info -l archive1.flar aaa aaa/bbb aaa/bbb/ccc aaa/bbb/ccc/ddd aaa/bbb/fff aaa/eee aaa/eee ggg |
In this example, the archive is named archive4. This archive is copied exactly from the master system and then compressed. The archive is an exact duplicate of the master system and is stored in archive4.flar. The -R option is used to create the archive from another directory tree.
# flarcreate -n archive4 -c -R /x/yy/zz archive4.flar |
In this example, the archive is named archive3. This archive is copied exactly from the master system and then compressed. Options add descriptions to the archive-identification section, which can help you to identify the archive later. For information about keywords, their values, and formats, see Solaris Flash Keywords.
# flarcreate -n archive3 -i 20000131221409 -m pumbaa \ -e "Solaris 8 Print Server" -a "Mighty Matt" -U "Internal Finance" \ -T server archive3.flar |
After the archive is created, you can access the archive identification section that contains the detailed description. An example of an archive identification section follows.
section_begin=identification files_archived_method=cpio files_compressed_method=compress files_archived_size=259323342 files_unarchived_size=591238111 creation_date=20000131221409 creation_master=pumbaa content_name=Finance Print Server content_type=server content_description=Solaris 8 Print Server content_author=Mighty Matt content_architectures=sun4u creation_node=pumbaa creation_hardware_class=sun4u creation_platform=SUNW,Sun-Fire creation_processor=sparc creation_release=5.9 creation_os_name=SunOS creation_os_version=s81_49 x-department=Internal Finance |
In this example, the archive is named archive2. This archive is copied from the master system but is not an exact copy. The content under the /aaa directory is excluded, but the content in /aaa/bbb/ccc remains.
# flarcreate -n archive2 -x /aaa -y /aaa/bbb/ccc archive2.flar |
To check the file structure of the archive, type the following. The excluded directories that include copied files appear, but only the files that were restored contain data.
# flar info -l aaa aaa aaa/bbb/ccc aaa/bbb/ccc/ddd aaa/bbb ggg |
In this example, the archive is named archive5. This archive is copied from the master system but is not an exact copy.
The exclude file contains the following list:
/aaa |
The include file contains the following list:
/aaa/bbb/ccc |
# flarcreate -n archive5 -X exclude -f include archive5.flar |
To check about the file structure of the archive, type the following. The excluded directories that include copied files appear, but only the files that were restored contain data.
# flar info -l archive5.flar aaa aaa/bbb/ccc aaa/bbb/ccc/ddd aaa/bbb ggg |
You can combine options -x, -y, -X and -f. In this example, options -X and -y are combined. The archive is named archive5. This archive is copied from the master system but is not an exact copy.
/aaa |
The -y option restores the /aaa/bbb/ccc directory. The following command produces the archive.
# flarcreate -n archive5 -X exclude -y /aaa/bbb/ccc archive5.flar |
# flar info -l archive5.flar aaa aaa/bbb aaa/bbb/ccc aaa/bbb/ccc/ddd ggg |
In this example, the archive is named archive3. It is copied from the master system but is not an exact copy. The files and directories to be selected are included in filter1 file. Within the files, the directories are marked with a minus (-) or a plus (+) to indicate which files to exclude and restore. In this example, the directory /aaa is excluded with a minus and the subdirectory /aaa/bbb/ccc is restored with a plus. The filter1 file contains the following list.
- /aaa + /aaa/bbb/ccc |
# flarcreate -n archive3 -z filter1 archive3.flar |
To check the file structure of the archive, type the following command. The excluded directories that include copied files appear, but only the files that were restored contain data.
# flar info -l archive3.flar aaa aaa/bbb aaa/bbb/ccc aaa/bbb/ccc/ddd ggg |
Before creating a differential archive, you need two images to compare: an unchanged master image and an updated master image. One image is the unchanged master image that has been kept unchanged. This image was stored and needs to be accessed. The second image is the unchanged master image that is updated with minor changes. The root (/) file system is the default for the new image, but you can access this image if it has been stored elsewhere. After you have the two images, you can create a differential archive, which contains only the differences between the two images. The differential archive can then be installed on clones that were installed previously with the unchanged master image.
Prepare the master system with changes. Before changes are made, the master system should be running a duplicate of the original archive.
A copy of the unchanged master image must be kept protected from changes and available for mounting later.
Update the unchanged master image with any of the following changes.
Delete packages.
Add packages or patches.
Modify configuration files.
Add support for peripheral devices on the clone system.
(Optional) Create custom scripts. See Creating Customization Scripts.
Deliver the unchanged master image in a mount point.
If the unchanged master image is stored on an inactive boot environment, retrieve it by using the lumount command.
# lumount BE_name mountpoint |
Specifies the boot environment name where the unchanged master image is stored
Specifies a root (/) file system where the image is stored
In the following example, the inactive boot environment is named unchanged_master1. The mount point is the directory /a on the master system.
# lumount unchanged_master1 /a |
If the image is stored on a clone, mount the clone by using NFS.
On the master system, share the clone's root (/) file system and give the master root permissions on the clone system.
# share -F nfs -o rw,root=master_system "/" |
master_system is the name of the master system.
On the master system, mount the clone.
# mount -F nfs clone_system:/ master_dir |
Specifies the name of the system to be mounted
Specifies the directory where the unchanged master image is stored
If you saved the image with the ufsdump command, use the ufsrestore command to retrieve a copy. For information about how to use these commands, see Chapter 27, UFS Backup and Restore Commands (Reference), in System Administration Guide: Devices and File Systems.
Create the differential archive.
# flarcreate -n archive_name -A unchanged_master_image_dir \ options path/filename |
Specifies the name that you give the archive. The archive_name you specify is the value of the content_name keyword. The name is listed in the archive-identification section.
Creates a differential archive by comparing a new system image with the image that is specified by the unchanged_master_image_dir argument. By default, the new system image is root (/). You can change the default with the -R option. unchanged_master_image_dir is a directory where the unchanged system image is stored or mounted through UFS, NFS, or the lumount command.
You can include and exclude some files by using the options for contents selection. For a list of options, see flar Command.
Specifies the path to the directory in which you want to save the archive file. If you do not specify a path, flarcreate saves the archive file in the current directory.
Specifies the name of the archive file.
If the differential archive creation is successful, the flarcreate command returns an exit code of 0.
If the differential archive creation fails, the flarcreate command returns a nonzero exit code.
For procedures about installing an archive, see To Prepare to Install a Solaris Flash Archive With a Custom JumpStart Installation in Solaris 10 10/08 Installation Guide: Custom JumpStart and Advanced Installations.
In this example, the directory for unchanged master image is named unchanged_master1. The new master image that contains changes is the root (/) directory. The new master image is compared to the unchanged master image and the resulting differential archive is then compressed. The differential archive is stored in diffarchive1.flar file. The archive contains files that are to be deleted, changed, or added when installed.
# flarcreate -n diffarchive1 -A /a/unchanged_master1 -c diffarchive1.flar |
In this example, the unchanged master image, unchanged_master1, is stored on an inactive boot environment and is accessed by mounting the boot environment. The new master image is the root (/) directory. The new master image is compared to the unchanged master and the resulting differential archive is then compressed. The archive is stored in diffarchive4.flar. The archive contains files that are to be deleted, changed, or added when installed.
# lumount unchanged_master1 /a # flarcreate -n diffarchive4 -A /a -c diffarchive4.flar |
To manage system updates, you can use Solaris Live Upgrade to copy the OS, which creates a new boot environment. This copy can be compared to the master system that has been updated with minor changes. The resulting Solaris Flash differential archive can then be installed on clone systems.
For more information about Solaris Live Upgrade, see Chapter 2, Solaris Live Upgrade (Overview), in Solaris 10 10/08 Installation Guide: Solaris Live Upgrade and Upgrade Planning.
From the unchanged master system, create a new boot environment by using the lucreate command.
This new boot environment is an exact copy of the master system and can be used to create the differential archive.
Check the status of the two boot environments.
# lustatus copy_BE boot environment Is Active Active Can Copy Name Complete Now OnReboot Delete Status ------------------------------------------------------------------------ master_BE yes yes yes no - copy_BE yes no no yes - |
Update the master image with any of the following changes.
Delete packages.
Mount the newly created boot environment.
# lumount BE_name /a |
Create the differential archive by comparing the master system to the boot environment.
# flarcreate -n archive_name -A new_BE_dir\ options path/filename |
Creates a differential archive by comparing a new system image with the image that is specified by the new BE_dir argument.
Unmount the new boot environment.
# luumount copy_BE |
The flarcreate command returns an exit code.
If the creation is successful, an exit code of 0 is returned.
If a failure occurs, a nonzero exit code is returned.
Install the Solaris Flash differential archive by using a JumpStart profile.
The clone systems that are to be installed must be a duplicate of the original master system or the installation fails.
The following example profile installs a differential archive, test.diff, on the device c1t1d0s0.
JumpStart profile ----------------------- install_type flash_update archive_location http server /rw/test.diff root_device c1t1d0s0 |
master_BE is the name of the current boot environment. copy_BE is the name of the new boot environment. The file systems root (/) and /usr are placed on s0 and s3. The lustatus command reports that the new boot environment copy is complete. The SUNWman package is added to the master system. After the master system is updated by adding the SUNWman package, the flarcreate command creates a differential archive by comparing the changed master and the unchanged new boot environment.
# lucreate -c master_BE -m /:/dev/dsk/c0t1d0s0:ufs \ -m /usr:/dev/dsk/c0t1d0s3:ufs -n copy_BE # lustatus # pkgadd SUNWman # lumount copy_BE /a # flarcreate -n test.diff -c -A /a /net/server/export/test.diff # luumount copy_BE |
Install the differential archive on clone systems. For procedures about installing an archive, see To Prepare to Install a Solaris Flash Archive With a Custom JumpStart Installation in Solaris 10 10/08 Installation Guide: Custom JumpStart and Advanced Installations.
The following image shows the creation of the new boot environment by using the lucreate command.
