Use the following checklist to gather the information that you need to upgrade the Solaris OS. You do not need to gather all of the information that is requested on the checklist. You only need to collect the information that applies to your system. If you are performing the upgrade over the network, the installation program provides the information for you, based on the current system configuration.
You cannot change basic system identification, such as host name or IP address. The installation program might prompt you for basic system identification, but you must enter the original values. If you use the Solaris installation program to upgrade, the upgrade fails if you attempt to change any of the values.
Table 5–2 Upgrade Checklist
Information for Upgrade |
Description or Example |
Answer – Defaults are noted with an asterisk (*) |
Network connection |
Is the system connected to a network? |
Networked/Nonnetworked |
DHCP |
Can the system use Dynamic Host Configuration Protocol (DHCP) to configure its network interfaces? DHCP provides the network parameters that are necessary for installation. |
Yes/No* |
If you are not using DHCP, note the network address. |
IP Address |
If you are not using DHCP, supply the IP address for the system. Example: 172.31.255.255 To find this information on a running system, type the following command.
Subnet |
If you are not using DHCP, is the system part of a subnet? If yes, what is the netmask of the subnet? Example: 255.255.255.0 To find this information on a running system, type the following command.
IPv6 |
Do you want to enable IPv6 on this machine? IPv6 is a part of the TCP/IP Internet protocol that facilitates IP addressing by adding better security and increasing Internet addresses. |
Yes/No* |
Host name |
Host name that you choose for the system. To find this information on a running system, type the following command.
Kerberos |
Do you want to configure Kerberos security on this machine? If yes, gather this information: |
Yes/No* |
Default Realm: | ||||
Administration Server: | ||||
First KDC: | ||||
The Kerberos service is a client-server architecture that provides secure transactions over networks. | ||||
If the system uses a naming service, provide the following information. |
Naming service |
Which naming service should this system use? To find this information on a running system, type the following command.
A naming service stores information in a central place, which enables users, machines, and applications to communicate across the network. Examples of information that is stored are host names and addresses or user names and passwords. |
NIS+/NIS/DNS/ LDAP/None |
Domain name |
Provide the name of the domain in which the system resides. During installation, you can choose the default NFSv4 domain name. Or, you can specify a custom NFSv4 domain name.
NIS+ and NIS |
Do you want to specify a name server or let the installation program find one? If you want to specify a name server, provide the following information. |
Specify one/Find one* |
Server's host name: | ||||
Server's IP Address: | ||||
Network Information Service (NIS) makes network administration more manageable by providing centralized control over a variety of network information, such as machine names and addresses. | ||||
DNS |
Provide IP addresses for the DNS server. You must enter at least one IP address, but you can enter up to three addresses. | |||
To display the server's IP address, type the following command.
You can enter a list of domains to search when a DNS query is made. | ||||
List of domains to be searched: | ||||
The domain name system (DNS) is the naming service that the Internet provides for TCP/IP networks. DNS provides host names to the IP address service. DNS simplifies communication by using machine names instead of numerical IP addresses. DNS also serves as a database for mail administration. | ||||
LDAP |
Provide the following information about your LDAP profile. | |||
Profile Name: | ||||
Profile Server: | ||||
If you specify a proxy credential level in your LDAP profile, gather this information. | ||||
Proxy-bind distinguished name: | ||||
Proxy-bind password: | ||||
Lightweight Directory Access Protocol (LDAP) defines a relatively simple protocol for updating and searching directories that are running over TCP/IP. | ||||
Default route |
Do you want to specify a default route IP address or let the Solaris installation program find one? The default route provides a bridge that forwards traffic between two physical networks. An IP address is a unique number that identifies each host on a network. You have the following choices:
Detect one*/Specify one/None |
Time zone |
How do you want to specify your default time zone? |
Geographic region* Offset from GMT Time zone file |
Root password |
Provide the root password for the system. | |||
Default or custom installation |
Do you want to perform a default installation, or customize the installation?
Note – The text installer does not prompt you to select a Default or Custom Installation. To perform a default installation, accept the default values that are provided in the text installer. To perform a custom installation, edit the values in the text installer screens. |
Default installation*/Custom installation |
Keyboard |
This feature is new in the following releases:
If the keyboard is self-identifying, the keyboard language and layout automatically configures during installation. If the keyboard is not self-identifying, the sysidkdb tool provides you, during the installation, a list of supported keyboard layouts during installation, so that you can select a layout for keyboard configuration. SPARC: Previously, the USB keyboard assumed a self-identifying value of 1 during the installation. Therefore, all of the keyboards that were not self-identifying always configured for a U.S. English keyboard layout during installation. For further information, see Preconfiguring With the sysidcfg File in Solaris 10 5/09 Installation Guide: Network-Based Installations. | |||
Locales |
For which geographic regions do you want to install support? Note – The locale can be preconfigured by NIS or NIS+. For more information, see sysidcfg File Keywords in Solaris 10 5/09 Installation Guide: Network-Based Installations. | |||
SPARC: Power Management (only available on SPARC systems that support Power Management) |
Do you want to use Power Management? Note – If your system has Energy Star version 3 or later, you are not prompted for this information. |
Yes/No |
Automatic reboot or CD/DVD ejection |
Reboot automatically after software installation? Eject CD/DVD automatically after software installation? |
Yes*/No Yes*/No |
Disk space reallocation |
Do you want the installation program to automatically re-layout the systems on your disks? If yes, which file system should be used for auto-layout? Example: /, /opt, /var If no, you must provide information for the system configuration. |
Yes/No* |
If you are installing through a tip line, follow these instructions. |
Ensure that your window display is at least 80 columns wide and 24 rows long. For more information, see tip(1). To determine the current dimensions of your tip window, use the stty command. For more information, see the man page, stty(1). | |||
Check your Ethernet connection. |
If the system is part of a network, verify that an Ethernet connector or similar network adapter is connected to your system. | |||
Solaris Live Upgrade use |
Check the system for the existence of Prestoserve software. |
If you begin the upgrade process by shutting down the system with the init 0 command and you're using Prestoserve software, you might lose data. Refer to the Prestoserve documentation for shutdown instructions. | |||
Check for patches needed. |
The most recent patch list is provided at http://sunsolve.sun.com. | |||
Review the planning chapter and other relevant documentation. |
