Solaris 10 5/09 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Chapter 7 Maintaining Solaris Live Upgrade Boot Environments (Tasks)
This chapter explains various maintenance tasks such as keeping a boot environment file system up to date or deleting a boot environment. This chapter contains the following sections:
Note –
This chapter describes Solaris Live Upgrade for UFS file systems. The usage for the maintenance for a ZFS boot environment is the same. For procedures for migrating a UFS file system to a ZFS root pool or creating and installing a ZFS root pool, see Chapter 13, Creating a Boot Environment for ZFS Root Pools.
Overview of Solaris Live Upgrade Maintenance
Table 7–1 Overview of Solaris Live Upgrade Maintenance
Task
Description
For Instructions
(Optional) View Status.
  • View whether a boot environment is active, being activated, scheduled to be activated, or in the midst of a comparison.
  • Compare the active and inactive boot environments.
  • Display the name of the active boot environment.
  • View the configurations of a boot environment.
(Optional) Update an inactive boot environment.
Copy file systems from the active boot environment again without changing the configuration of file systems.
Updating a Previously Configured Boot Environment
(Optional) Other tasks.
  • Delete a boot environment.
  • Change the name of a boot environment.
  • Add or change a description that is associated with a boot environment name.
  • Cancel scheduled jobs.
Displaying the Status of All Boot Environments
Use the lustatus command to display the information about the boot environment. If no boot environment is specified, the status information for all boot environments on the system is displayed.
The following details for each boot environment are displayed:
ProcedureTo Display the Status of All Boot Environments
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # lustatus BE_name
    BE_name
    Specifies the name of the inactive boot environment to view status. If BE_name is omitted, lustatus displays status for all boot environments in the system.
    In this example, the status for all boot environments is displayed.
    # lustatus
    boot environment   Is        Active  Active     Can	    Copy
    Name               Complete  Now	 OnReboot   Delete	 Status
    disk_a_S9           yes       yes     yes        no       -
    disk_b_S10database   yes       no      no         yes      COPYING
    disk_b_S9a          no        no      no         yes      -
    Note –
    You could not perform copy, rename, or upgrade operations on disk_b_S9a because it is not complete, nor on disk_b_S10database because a live upgrade operation is in progress.
You can update the contents of a previously configured boot environment with the Copy menu or the lumake command. File Systems from the active (source) boot environment are copied to the target boot environment. The data on the target is also destroyed. A boot environment must have the status “complete” before you can copy from it. See Displaying the Status of All Boot Environments to determine a boot environment's status.
The copy job can be scheduled for a later time, and only one job can be scheduled at a time. To cancel a scheduled copy, see Canceling a Scheduled Create, Upgrade, or Copy Job.
ProcedureTo Update a Previously Configured Boot Environment
This procedure copies source files over outdated files on a boot environment that was previously created.
  2. Type:
    # lumake -n  BE_name [-s source_BE] [-t  time] [-m email_address]
    -n BE_name
    Specifies the name of the boot environment that has file systems that are to be replaced.
    -s source_BE
    (Optional) Specifies the name of the source boot environment that contains the file systems to be copied to the target boot environment. If you omit this option, lumake uses the current boot environment as the source.
    -t time
    (Optional) Set up a batch job to copy over file systems on a specified boot environment at a specified time. The time is given in the format that is specified by the man page, at(1).
    -m email_address
    (Optional) Enables you to send an email of the lumake output to a specified address on command completion. email_address is not checked. You can use this option only in conjunction with -t.
Example 7–1 Updating a Previously Configured Boot Environment
In this example, file systems from first_disk are copied to second_disk. When the job is completed, an email is sent to Joe at anywhere.com.
# lumake -n  second_disk -s first_disk -m joe@anywhere.com
The files on first_disk are copied to second_disk and email is sent for notification. To cancel a scheduled copy, see Canceling a Scheduled Create, Upgrade, or Copy Job.
A boot environment's scheduled creation, upgrade, or copy job can be canceled just prior to the time the job starts. The job can be scheduled by the lumake command. At any time, only one job can be scheduled on a system.
ProcedureTo Cancel a Scheduled Create, Upgrade, or Copy Job
  2. Type:
    # lucancel
    The job no longer executes at the time that is specified.
Comparing Boot Environments
Use the lucompare command to check for differences between the active boot environment and other boot environments. To make a comparison, the inactive boot environment must be in a complete state and cannot have a copy job that is pending. See Displaying the Status of All Boot Environments.
The lucompare command generates a comparison of boot environments that includes the contents of any non-global zones.
The specified boot environment cannot have any partitions that are mounted with lumount or mount.
ProcedureTo Compare Boot Environments
  2. Type:
    # /usr/sbin/lucompare -i  infile (or) -t -o  outfile BE_name
    -i  infile
    Compare files that are listed in infile. The files to be compared should have absolute file names. If the entry in the file is a directory, then comparison is recursive to the directory. Use either this option or -t, not both.
    -t
    Compare only nonbinary files. This comparison uses the file(1) command on each file to determine if the file is a text file. Use either this option or -i, not both.
    -o  outfile
    Redirect the output of differences to outfile.
    BE_name
    Specifies the name of the boot environment that is compared to the active boot environment.
Example 7–2 Comparing Boot Environments
In this example, first_disk boot environment (source) is compared to second_disk boot environment and the results are sent to a file.
# /usr/sbin/lucompare -i  /etc/lu/compare/ \
-o /var/tmp/compare.out second_disk
Deleting an Inactive Boot Environment
Use the ludelete command to remove a boot environment. Note the following limitations.
ProcedureTo Delete an Inactive Boot Environment
  2. Type:
    # ludelete BE_name
    BE_name
    Specifies the name of the inactive boot environment that is to be deleted
Example 7–3 Deleting an Inactive Boot Environment
In this example, the boot environment, second_disk, is deleted.
# ludelete second_disk
Displaying the Name of the Active Boot Environment
Use the lucurr command to display the name of the currently running boot environment. If no boot environments are configured on the system, the message “No Boot Environments are defined” is displayed. Note that lucurr reports only the name of the current boot environment, not the boot environment that is active on the next reboot. See Displaying the Status of All Boot Environments to determine a boot environment's status.
ProcedureTo Display the Name of the Active Boot Environment
  2. Type:
    # /usr/sbin/lucurr
Example 7–4 Displaying the Name of the Active Boot Environment
In this example, the name of the current boot environment is displayed.
# /usr/sbin/lucurr
solaris10
Changing the Name of a Boot Environment
Renaming a boot environment is often useful when you upgrade the boot environment from one Solaris release to another release. For example, following an operating system upgrade, you might rename the boot environment solaris8 to solaris10.
Use the lurename command to change the inactive boot environment's name.
x86 only –
Starting with the Solaris 10 1/06 release, the GRUB menu is automatically updated when you use the Rename menu or lurename command. The updated GRUB menu displays the boot environment's name in the list of boot entries. For more information about the GRUB menu, see Booting Multiple Boot Environments.
To determine the location of the GRUB menu's menu.lst file, see Chapter 14, Managing the Solaris Boot Archives (Tasks), in System Administration Guide: Basic Administration.
Table 7–2 Limitations for Naming a Boot Environment
Limitation
For Instructions
The name must not exceed 30 characters in length.
The name can consist only of alphanumeric characters and other ASCII characters that are not special to the UNIX shell.
See the “Quoting” section of sh(1).
The name can contain only single-byte, 8-bit characters.
The name must be unique on the system.
A boot environment must have the status “complete” before you rename it.
You cannot rename a boot environment that has file systems mounted with lumount or mount.
ProcedureTo Change the Name of an Inactive Boot Environment
  2. Type:
    # lurename -e  BE_name -n  new_name
    -e BE_name
    Specifies the inactive boot environment name to be changed
    -n new_name
    Specifies the new name of the inactive boot environment
    In this example, second_disk is renamed to third_disk.
    # lurename -e  second_disk  -n  third_disk
Adding or Changing a Description Associated With a Boot Environment Name
You can associate a description with a boot environment name. The description never replaces the name. Although a boot environment name is restricted in length and characters, the description can be of any length and of any content. The description can be simple text or as complex as a gif file. You can create this description at these times:
For more information about using the -A option with lucreate
To Create a Boot Environment for the First Time
For more information about creating the description after the boot environment has been created
ludesc(1M)
ProcedureTo Add or Change a Description for a Boot Environment Name With Text
  2. Type:
    # /usr/sbin/ludesc -n  BE_name 'BE_description'
    Specifies the boot environment name and the new description to be associated with the name
Example 7–5 Adding a Description to a Boot Environment Name With Text
In this example, a boot environment description is added to a boot environment that is named second_disk. The description is text that is enclosed in single quotes.
# /usr/sbin/ludesc -n second_disk 'Solaris 10 5/09 test build'
ProcedureTo Add or Change a Description for a Boot Environment Name With a File
  2. Type:
    # /usr/sbin/ludesc -n BE_name -f file_name
    -n BE_name
    file_name
    Specifies the file to be associated with a boot environment name
Example 7–6 Adding a Description to a Boot Environment Name With a File
In this example, a boot environment description is added to a boot environment that is named second_disk. The description is contained in a gif file.
# /usr/sbin/ludesc -n second_disk -f rose.gif
ProcedureTo Determine a Boot Environment Name From a Text Description
The following command returns the name of the boot environment associated with the specified description.
  2. Type:
    # /usr/sbin/ludesc -A 'BE_description'
    -A 'BE_description'
    Specifies the description to be associated with the boot environment name.
Example 7–7 Determining a Boot Environment Name From a Description
In this example, the name of the boot environment, second_disk, is determined by using the -A option with the description.
# /usr/sbin/ludesc -A  'Solaris 10 5/09 test build'
 second_disk
ProcedureTo Determine a Boot Environment Name From a Description in a File
The following command displays the boot environment's name that is associated with a file. The file contains the description of the boot environment.
  2. Type:
    # /usr/sbin/ludesc -f  file_name
    -f file_name
    Specifies the name of the file that contains the description of the boot environment.
Example 7–8 Determining a Boot Environment Name From a Description in a File
In this example, the name of the boot environment, second_disk, is determined by using the -f option and the name of the file that contains the description.
# /usr/sbin/ludesc -f rose.gif
second_disk
ProcedureTo Determine a Boot Environment Description From a Name
This procedure displays the description of the boot environment that is named in the command.
  2. Type:
    -n BE_name
    Specifies the boot environment name.
Example 7–9 Determining a Boot Environment Description From a Name
In this example, the description is determined by using the -n option with the boot environment name.
Viewing the Configuration of a Boot Environment
Use the lufslist command to list the configuration of a boot environment. The output contains the disk slice (file system), file system type, and file system size for each boot environment mount point.
ProcedureTo View the Configuration of a Boot Environment
  2. Type:
    # lufslist -n BE_name
    BE_name
    Specifies the name of the boot environment to view file system specifics
    The following example displays a list.
    Filesystem                fstype       size(Mb) Mounted on
    /dev/dsk/c0t0d0s1         swap           512.11 -
    /dev/dsk/c0t4d0s3         ufs           3738.29 /
    /dev/dsk/c0t4d0s4         ufs            510.24 /opt
    Note –
    For an example of a list that contains non-global zones, see To View the Configuration of a Boot Environment's Non-Global Zone File Systems.
