Solaris 10 5/09 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Guidelines for Selecting a Slice for a Swap Volume
These guidelines contain configuration recommendations and examples for a swap slice.
Configuring Swap for the New Boot Environment
You can configure a swap slice in three ways by using the lucreate command with the -m option:
The following examples show the three ways of configuring swap. The current boot environment is configured with the root (/) file system on c0t0d0s0. The swap file system is on c0t0d0s1.
Failed Boot Environment Creation if Swap is in Use
A boot environment creation fails if the swap slice is being used by any boot environment except for the current boot environment. If the boot environment was created using the -s option, the alternate-source boot environment can use the swap slice, but not any other boot environment.
