This section provides the procedure for using Solaris Live Upgrade to install Solaris Flash archives. Installing a Solaris Flash archive overwrites all files on the new boot environment except for shared files. Archives are stored on the following media:
HTTP server
FTP server – Use this path from the command line only
NFS server
Local file
Local tape
Local device, including DVD or CD
Note the following issues with installing and creating a Solaris Flash archive.
Description |
For More Information |
For examples of the correct syntax for paths that are associated with archive storage. | |
To use the Solaris Flash installation feature, you install a master system and create the Solaris Flash archive. |
For more information about creating an archive, see Chapter 3, Creating Solaris Flash Archives (Tasks), in Solaris 10 5/09 Installation Guide: Solaris Flash Archives (Creation and Installation). |
Install the Solaris Live Upgrade SUNWlucfg, SUNWlur, and SUNWluu packages on your system. These packages must be from the release you are upgrading to. For step-by-step procedures, see To Install Solaris Live Upgrade With the pkgadd Command.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Type:
# luupgrade -f -n BE_name -s os_image_path -a archive |
Indicates to install an operating system from a Solaris Flash archive.
Specifies the name of the boot environment that is to be installed with an archive.
Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory. This OS image provides a miniroot that boots a minimal, bootable root (/) file system to facilitate the installation of the Solaris Flash archive. The miniroot is not the image that is installed. The -a option provides the operating system image.
Path to the Solaris Flash archive when the archive is available on the local file system. The operating system image versions that are specified with the -s option and the -a option must be identical.
In this example, an archive is installed on the second_disk boot environment. The archive is located on the local system. The -s option provides a miniroot that boots a minimal, bootable root (/) file system to facilitate the installation of the Solaris Flash archive. The miniroot is not the image that is installed. The -a option provides the operating system image. The operating system versions for the -s and -a options are both Solaris 10 5/09 releases. All files are overwritten on second_disk except shareable files. The pkgadd command adds the Solaris Live upgrade packages from the release you are upgrading to.
# pkgadd -d /server/packages SUNWlucfg SUNWlur SUNWluu # luupgrade -f -n second_disk \ -s /net/installmachine/export/Solaris_10/OS_image \ -a /net/server/archive/10 |
The boot environment is ready to be activated. See Activating a Boot Environment.
This procedure provides the steps to install a Solaris Flash archive or differential archive by using a profile.
If you added locales to the profile, make sure that you have created a boot environment with additional disk space.
Create a profile.
See To Create a Profile to be Used by Solaris Live Upgrade for a list of keywords that can be used in a Solaris Live Upgrade profile.
Type:
# luupgrade -f -n BE_name -s os_image_path -j profile_path |
Specifies the name of the boot environment that is to be upgraded.
Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory. This OS image provides a miniroot that boots a minimal, bootable root (/) file system to facilitate the installation of the Solaris Flash archive. The miniroot is not the image that is installed. The -j option provides the path to the profile that contains the Solaris Flash archive operating system image.
Path to a JumpStart profile that is configured for a flash installation. The profile must be in a directory on the local machine. The -s option's operating system version and the Solaris Flash archive operating system version must be identical.
In this example, a profile provides the location of the archive to be installed.
# profile keywords profile values # ---------------- ------------------- install_type flash_install archive_location nfs installserver:/export/solaris/flasharchive/solarisarchive
After creating the profile, you can run the luupgrade command and install the archive. The -s option provides a miniroot that boots a minimal, bootable root (/) file system to facilitate the installation of the Solaris Flash archive. The miniroot is not the image that is installed. The -j option provides the path to the profile that contains the path to the Solaris Flash archive operating system image. The -j option is used to access the profile. The pkgadd command adds the Solaris Live Upgrade packages from the release you are upgrading to.
# pkgadd -d /server/packages SUNWlucfg SUNWlur SUNWluu # luupgrade -f -n second_disk \ -s /net/installmachine/export/solarisX/OS_image \ -j /var/tmp/profile |
The boot environment is then ready to be activated. See Activating a Boot Environment.
To create a profile, see To Create a Profile to be Used by Solaris Live Upgrade.
This procedure enables you to install a Solaris Flash archive and use the archive_location keyword at the command line rather than from a profile file. You can quickly retrieve an archive without the use of a profile file.
Type:
# luupgrade -f -n BE_name -s os_image_path -J 'archive_location path-to-profile' |
Specifies to upgrade an operating system from a Solaris Flash archive.
Specifies the archive_location profile keyword and the path to the JumpStart profile. The -s option's operating system version and the Solaris Flash archive operating system version must be identical. For the keyword values, see archive_location Keyword in Solaris 10 5/09 Installation Guide: Custom JumpStart and Advanced Installations.
In this example, an archive is installed on the second_disk boot environment. The -s option provides a miniroot that boots a minimal, bootable root (/) file system to facilitate the installation of the Solaris Flash archive. The miniroot is not the image that is installed. The -j option provides the path to the Solaris Flash archive operating system image. The -J option and the archive_location keywords are used to retrieve the archive. All files are overwritten on second_disk except shareable files. The pkgadd command adds the Solaris Live Upgrade packages from the release you are upgrading to.
# pkgadd -d /server/packages SUNWlucfg SUNWlur SUNWluu # luupgrade -f -n second_disk \ -s /net/installmachine/export/solarisX/OS_image \ -J 'archive_location http://example.com/myflash.flar' |
