Solaris 10 5/09 Installation Guide: Custom JumpStart and Advanced Installations
x86: Command Reference for Booting the System
The following table describes the command-line options for the GRUB menu boot command. The options listed are appropriate for a JumpStart installation.
The syntax of the boot command is the following.
kernel /I86PC.Solaris_11-image_directory/multiboot kernel/unix/ - install \
[url|ask] options -B install_media=media_type
Table 6–4 GRUB Menu Boot Command Reference
Option
Description
- install
Performs a custom JumpStart installation.
In the following example, the system boots from DVD media and the following options were used:
  • - install performs a custom JumpStart
  • file://jumpstart/config.tar finds the JumpStart profile on the local disk
kernel /I86pc.Solaris_11.8/multiboot - install file://jumpstart/config.tar \
 -B install_media=dvdrom module /I86Solaris_11.8/x86.new
[url| ask]
Specifies the location of the custom JumpStart files or prompts you for the location.
  • url – Specifies the path to the files. You can specify a URL for files that are located on an HTTP or HTTPS server:
    The syntax for an HTTP server is the following:
    http://server_name:IP_address/jumpstart_dir_path/
    compressed_config_file&proxy_info
    • If you placed a sysidcfg file in the compressed configuration file, you must specify the IP address of the server that contains the file, as in the following example:
      kernel /I86pc.Solaris_11.8/multiboot install \
      http://192.168.2.1/jumpstart/config.tar \
       -B install_media=192.168.2.1/export/Solaris_11.8/boot \
      module /I86PC.Solaris_11.8/x86.new
    • If you saved the compressed configuration file on an HTTP server that is behind a firewall, you must use a proxy specifier during boot. You do not need to specify an IP address for the server that contains the file. You must specify an IP address for the proxy server, as in the following example:
      http://www.shadow.com/jumpstart/config.tar&proxy=131.141.6.151 \
  • ask – Specifies that the installation program prompt you to type the location of the compressed configuration file. You are prompted after the system boots and connects to the network. If you use this option, you are not able to do a completely hands off JumpStart installation.
    If you bypass the prompt by pressing Return, the Solaris installation program interactively configures the network parameters. The installation program then prompts you for the location of the compressed configuration file.
    The following example performs a custom JumpStart and boots from DVD media. You are prompted to type the location of the configuration file after the system connects to the network.
    kernal /boot/multiboot kernel/unix install ask -B \
    install_media=192.168.2.1:export/sol_11_x86/boot module \
    /I86PC.Solaris_11.8_
options
  • dhcp – Specifies to use a DHCP server to obtain network installation information that is needed to boot the system. This option is not needed for a JumpStart installation. If you do not specify to use a DHCP server by typing dhcp, the system uses the /etc/bootparams file or the naming service bootparams database. For example, you would not specify dhcp if you wanted keep a static IP address. For example:
    dhcp -B install_media=192.168.2.1:/export/Solaris_11.8/ \
    boot module /I86PC.Solaris_11.8/x86.new
  • The options nowin and text do not apply to a JumpStart installation. These options are useful with an interactive installation. For more information, see To Install or Upgrade With the Solaris Installation Program With GRUB in Solaris 10 5/09 Installation Guide: Basic Installations.
