Solaris 10 10/09 Installation Guide: Custom JumpStart and Advanced Installations
Profile Keywords Quick Reference
Table 8–2 provides a quick way to determine which keywords you can use, based on your installation scenario. Unless otherwise noted in the keyword descriptions, the keyword can only be used with the initial installation option. Also, these keywords are for a UFS file system unless noted that the keyword can be used in a ZFS root pool profile.
Table 8–2 Profile Keywords Overview
Installation Scenarios
Profile Keyword
Standalone System (Nonnetworked)
Standalone System (Networked) or Server
OS Server
Upgrade
Upgrade With Disk Space Reallocation
Can be Used for a ZFS Root Pool
archive_location (installing Solaris Flash archives)
backup_media
boot_device (UFS and ZFS)
bootenv (UFS and ZFS)
client_arch
client_root
client_swap
cluster (adding software groups) (UFS and ZFS)
cluster (adding or deleting clusters) (UFS and ZFS)
dontuse (UFS and ZFS)
fdisk (x86 only) (UFS and ZFS)
filesys (mounting remote file systems) (UFS and ZFS)
filesys (creating local file systems)
filesys (creating mirrored file systems)
forced_deployment (installing Solaris Flash differential archives)
geo (UFS and ZFS)
install_type (UFS and ZFS)
layout_constraint
local_customization (installing Solaris Flash archives)
locale (UFS and ZFS)
metadb (creating state database replicas)
no_master_check (installing Solaris Flash differential archives)
no_content_check (installing Solaris Flash differential archives)
num_clients
package (UFS and ZFS)
partitioning
patch
pool (ZFS root pools only)
root_device (UFS and ZFS)
system_type
usedisk (UFS and ZFS)
