Task |
Description |
For Instructions |
Decide how to upgrade the system if a previous version of the Solaris software is installed on the system. |
If a previous release of Solaris is installed on the system, you need to determine how to upgrade the system. Ensure that you know what to do before and after you upgrade a system. Planning helps you to create your profiles, begin scripts, and finish scripts. |
Upgrade Planning in Solaris 10 10/09 Installation Guide: Planning for Installation and Upgrade |
Create a JumpStart directory. |
On a server If you want to perform custom JumpStart installations on systems that are connected to a network, you must create a profile server. The profile server contains a JumpStart directory for the custom JumpStart files. | |
On a diskette If you want to perform custom JumpStart installations on systems that are not connected to a network, you must create a profile diskette. A profile diskette contains the custom JumpStart files. | ||
Add rules to the rules file. |
After you decide how you want each group of systems or single systems to be installed, create a rule for each group that you want to install. Each rule distinguishes a group, based on one or more system attributes. The rule links each group to a profile. | |
Create a profile for every rule. |
A profile is a text file that defines how to install the Solaris software, for example, which software group to install on a system. Every rule specifies a profile to define how a system is to be installed with the Solaris software when the rule is matched. You usually create a different profile for every rule. However, the same profile can be used in more than one rule. | |
(Optional) Test the profiles. |
After you create a profile, use the pfinstall(1M) command to test the profile before you use the profile to install or upgrade a system. | |
Validate the rules file. |
The rules.ok file is a generated version of the rules file that the JumpStart program uses to match the system to be installed with a profile. You must use the check script to validate the rules file. |
