Solaris 10 10/09 Installation Guide: Custom JumpStart and Advanced Installations
install_type Profile Keyword (UFS and ZFS)
Note –
The install_type keyword can be used for either a UFS file system or a ZFS root pool installation. The usage is limited for a ZFS installation. You can only use the intial_install option for a ZFS installation.
install_type initial_upgrade_flash_switch
install_type defines whether to erase and install a new Solaris OS on a system, upgrade the existing Solaris OS on a system, or install a Solaris Flash archive on the system.
Note –
You must specify install_type in a profile, and install_type must be the first profile keyword in every profile.
You must use one of the following options for the initial_upgrade_flash_switch:
initial_install
Specifies to perform an initial installation of the Solaris OS
upgrade
Specifies to perform an upgrade of the Solaris OS
flash_install
Specifies to install a Solaris Flash archive that overwrites all files
flash_update
Specifies to install a Solaris Flash differential archive that overwrites only the files that are specified
Note –
Some profile keywords can only be used with the initial_install option. Some profile keywords can only be used with the upgrade option. Some profile keywords can only be used with the flash_install option.
