Solaris 10 10/09 Installation Guide: Network-Based Installations
Creating a Boot Server on a Subnet With a CD Image
You must create an install server to install the Solaris software on a system from the network. You do not always need to set up a boot server. A boot server contains enough of the boot software to boot systems from the network, and then the install server completes the installation of the Solaris software.
ProcedureTo Create a Boot Server on a Subnet With a CD Image
  1. On the system you intend to make the boot server for the subnet, log in and become superuser or assume an equivalent role.
    The system must include a local CD-ROM drive or have access to the remote current Solaris release disc images, which are normally on the install server. If you use a naming service, the system should be in the naming service. If you do not use a naming service, you must distribute information about this system by following your site's policies.
  2. Mount the Solaris Software - 1 CD image from the install server.
    # mount -F nfs -o ro server_name:path /mnt
    Is the install server name and absolute path to the disc image
  3. Create a directory for the boot image.
    # mkdir -p boot_dir_path
    Specifies the directory where the boot software is to be copied
  4. Change to the Tools directory on the Solaris Software - 1 CD image.
    # cd /mnt/Solaris_10/Tools
  5. Copy the boot software to the boot server.
    # ./setup_install_server -b boot_dir_path
    Specifies to set up the system as a boot server
    Note –
    The setup_install_server command indicates whether you have enough disk space available for the images. To determine available disk space, use the df -kl command.
  6. Change directories to root (/).
    # cd /
  7. Unmount the installation image.
    # umount /mnt
Example 6–2 Creating a Boot Server on a Subnet With CD Media
The following example illustrates how to create a boot server on a subnet. These commands copy the boot software from the Solaris Software for SPARC Platforms - 1 CD image to /export/install/boot on the system's local disk.
# mount -F nfs -o ro crystal:/export/install/boot /mnt
# mkdir -p /export/install/boot
# ./setup_install_server -b /export/install/boot
# cd /
# umount /mnt
In this example, the disc is inserted and automatically mounted before the command. After the command, the disc is removed.
Continuing the Installation
After you set up the boot server, you must add the client as an installation client. For information about how to add client systems to install over the network, see Adding Systems to Be Installed From the Network With a CD Image.
See Also
For additional information about the setup_install_server command, see install_scripts(1M).
