Solaris 10 10/09 Installation Guide: Network-Based Installations
WAN Boot Installation Commands
The following tables describe the commands you use to perform a WAN boot installation.
Table 15–1 Preparing the WAN Boot Installation and Configuration Files
Task and Description
Command
Copy the Solaris installation image to install-dir-path, and copy the WAN boot miniroot to wan-dir-path on the install server's local disk.
setup_install_server –w wan-dir-path install-dir-path
Create a Solaris Flash archive that is named name.flar.
  • name is the name of the archive
  • optional-parameters are optional parameters you can use to customize the archive
  • document-root is the path to the document root directory on the install server
  • filename is the name of the archive
flarcreate – n name [optional-parameters] document-root/flash/filename
Check the validity of the custom JumpStart rules file that is named rules.
./check -r rules
Check the validity of the wanboot.conf file.
  • net-ip is the IP address of the client's subnet.
  • client-ID can be a user-defined ID or the DHCP client ID.
bootconfchk /etc/netboot/net-ip/client-ID/wanboot.conf
Check for WAN boot installation support in the client OBP.
eeprom | grep network-boot-arguments
Table 15–2 Preparing the WAN Boot Security Files
Command
Create a master HMAC SHA1 key for the WAN boot server.
wanbootutil keygen -m
Create a HMAC SHA1 hashing key for the client.
wanbootutil keygen -c -o net=net-ip,cid=client-ID,type=sha1
Create an encryption key for the client.
  • key-type is either 3des or aes.
wanbootutil keygen -c -o net=net-ip,cid=client-ID,type=key-type
Split a PKCS#12 certificate file and insert the certificate in the client's truststore.
  • p12cert is the name of the PKCS#12 certificate file.
wanbootutil p12split -i p12cert -t /etc/netboot/net-ip/client-ID/truststore
Split a PKCS#12 certificate file and insert the client certificate in the client's certstore.
  • keyfile is the name of the client's private key.
wanbootutil p12split -i p12cert -c /etc/netboot/net-ip/client-ID/certstore -k keyfile
Insert the client private key from a split PKCS#12 file in the client's keystore.
  • client-ID can be a user-defined ID or a DHCP client ID.
wanbootutil keymgmt -i -k keyfile -s /etc/netboot/net-ip/client-ID/keystore -o type=rsa
Display the value of a HMAC SHA1 hashing key.
wanbootutil keygen -d -c -o net=net-ip,cid=client-ID,type=sha1
Display the value of an encryption key.
wanbootutil keygen -d -c -o net=net-ip,cid=client-ID,type=key-type
Insert a hashing key or an encryption key on a running system. key-type can have a value of sha1, 3des, or aes.
/usr/lib/inet/wanboot/ickey -o type=key-type
