Solaris 10 10/09 Installation Guide: Planning for Installation and Upgrade
Chapter 6 ZFS Root File System Installation (Planning)
This chapter provides system requirements and limitations to assist you when you install a ZFS root pool. Also provided is an overview of the installation programs that can install a ZFS root pool.
If you have multiple boot environments on your system see Chapter 7, SPARC and x86 Based Booting (Overview and Planning) for information on booting.
What's New in the Solaris 10 10/09 Release
Starting with the Solaris 10 10/09 release, you can set up a JumpStart profile to identify a flash archive of a ZFS root pool.
A Flash archive can be created on a system that is running a UFS root file system or a ZFS root file system. A Flash archive of a ZFS root pool contains the entire pool hierarchy, except for the swap and dump volumes, and any excluded datasets. The swap and dump volumes are created when the Flash archive is installed.
You can use the Flash archive installation method as follows:
For detailed instructions and limitations, see Installing a ZFS Root File System (Flash Archive Installation) in Solaris ZFS Administration Guide.
Requirements for Installing a ZFS Root Pool
Table 6–1 System Requirements and Limitations
Requirement or Limitation
Description
Information
Memory
786 MB is the minimum memory. 1 GB is recommended for overall performance.
Disk space
The minimum amount of available pool space for a bootable ZFS root file system depends on the amount of physical memory, the disk space available, and the number of boot environments to be created.
For an explanation, see Disk Space Requirements for a ZFS Installation.
The ZFS storage pool must be created with slices rather than whole disks to be upgradeable and bootable.
  • The pool created with slices can be mirrored but not a RAID-Z or non-redundant configuration of multiple disks. The SVM device information must be already available in the /dev/md/[r]dsk directory.
  • The pool must have an SMI label. An EFI-labeled disk cannot be booted.
  • x86 only: The ZFS pool must be in a slice with an fdisk partition.
When you migrate from a UFS root (/) file system to a ZFS root pool with Solaris Live Upgrade, consider these requirements.
  • Migrating from a UFS file system to a ZFS root pool with Solaris Live Upgrade or creating a new boot environment in a root pool is new starting with the Solaris 10 10/08 release. This release contains the software needed to use Solaris Live Upgrade with ZFS. You must have at least this release installed to use ZFS with Solaris Live Upgrade.
  • Migration is possible only from a UFS file system to a ZFS file system.
    • File systems other than a UFS file system cannot be migrated to a ZFS root pool.
    • A UFS file system cannot be created from a ZFS root pool.
  • Before migrating, a ZFS storage pool must exist.
Normally, on a system with a UFS root file system, swap and dump are on the same slice. Therefore, UFS shares the swap space with the dump device. In a ZFS root pool, swap and dump are separate zvols, so they do not share the same physical space. When a system is installed or upgraded with a ZFS root file system, the size of the swap area and the dump device are dependent on the amount of physical memory. The minimum amount of available pool space for a bootable ZFS root file system depends on the amount of physical memory, the disk space available, and the number of boot environments to be created. Approximately 1 Gbyte of memory and at least 2 Gbytes of disk space are recommended. The space is consumed as follows:
Solaris Installation Programs for Installing ZFS Root Pools
The following installation programs perform an initial installation of a ZFS root pool.
Solaris Live Upgrade can migrate a UFS file system to a ZFS root pool. Also, Solaris Live Upgrade can create ZFS boot environments that can be upgraded.
Table 6–2 ZFS Installation Programs and Limitations
Description
Limitations
Information
Solaris Installation program text installer
The Solaris text installer performs an initial installation for a ZFS root pool. During the installation, you can choose to install either a UFS file system or a ZFS root pool. You can set up a mirrored ZFS root pool by selecting two or more slices during the installation. Or, you can attach or add additional disks after the installation to create a mirrored ZFS root pool. Swap and dump devices on ZFS volumes are automatically created in the ZFS root pool.
  • The installation GUI is not available to install a ZFS root pool.
  • You cannot use the standard upgrade program to upgrade. You must use Solaris Live Upgrade to upgrade a ZFS root pool.
Chapter 3, Installing With the Solaris Interactive Text Installer for ZFS Root Pools (Planning and Tasks), in Solaris 10 10/09 Installation Guide: Basic Installations
You can use the Solaris Live Upgrade feature to perform the following tasks:
  • Migrate a UFS root (/) file system to a ZFS root pool
  • Create a new boot environment in the following ways:
    • Within an existing ZFS root pool
    • Within another ZFS root pool
    • From a source other than the currently running system
    • On a system with non-global zones installed
After you have used the lucreate command to create a ZFS boot environment, you can use the other Solaris Live Upgrade commands on the boot environment.
A storage pool must be created before you use the lucreate command.
Chapter 11, Solaris Live Upgrade and ZFS (Overview), in Solaris 10 10/09 Installation Guide: Solaris Live Upgrade and Upgrade Planning
JumpStart
Starting with the Solaris 10 10/09 release, you can set up a JumpStart profile to identify a flash archive of a ZFS root pool. See What's New in the Solaris 10 10/09 Release.
You can create a profile to create a ZFS storage pool and designate a bootable ZFS file system. New ZFS keywords provide an initial installation.
  • You cannot use the install_type upgrade keyword to upgrade a ZFS root pool. Nor can you use the Solaris Flash keywords.
  • Some keywords that are allowed in a UFS specific profile are not allowed in a ZFS specific profile.
