Sun Java System Directory Server Enterprise Edition 6.3 Administration Guide
ProcedureTo Add or Modify Browsing Index Entries
A browsing index is specific to a given search on a given base entry and its subtree. The browsing index configuration is defined in the database configuration of the suffix that contains the entry.
  1. Configure the vlvBase, vlvScope, and vlvFilter attributes for each browsing index on a directory server.
    These attributes configure the base of the search, the scope of the search, and a filter for the search. These attributes use the vlvSearch object class.
  2. Configure the vlvSort attribute for each browsing index.
    This attribute specifies the name of the attribute or attributes that sort the index. This entry is a child of the first entry and uses the vlvIndex object class to specify which attributes to sort and in what order.
    The following example uses the ldapmodify command to create the browsing index configuration entries:
    $ ldapmodify -a -h host -p port -D cn=admin,cn=Administrators,cn=config -w -
    Enter bind password:
    dn: cn=people_browsing_index, cn=database-name,
    cn=ldbm database,cn=plugins,cn=config
    objectClass: top
    objectClass: vlvSearch
    cn: Browsing ou=People
    vlvBase: ou=People,dc=example,dc=com
    vlvScope: 1
    vlvFilter: (objectclass=inetOrgPerson)
    dn: cn=Sort rev employeenumber, cn=people_browsing_index,
     cn=database-name,cn=ldbm database,cn=plugins,cn=config
    objectClass: top
    objectClass: vlvIndex
    cn: Sort rev employeenumber
    vlvSort: -employeenumber
    ^D
    The vlvScope is one of the following:
    • 0 for the base entry alone
    • 1 for the immediate children of the base
    • 2 for the entire subtree rooted at the base
    The vlvFilter is the same LDAP filter that is used in the client search operations. Because all browsing index entries are located in the same place, you should use descriptive cn values to name your browsing indexes.
    Each vlvSearch entry must have at least one vlvIndex entry. The vlvSort attribute is a list of attribute names that defines the attribute to sort on and the sorting order. The dash ( -) in front of an attribute name indicates reverse ordering. You can define more than one index for a search by defining several vlvIndex entries. With the previous example, you could add the following entry:
    dn: cn=Sort sn givenname uid, cn=people_browsing_index,
    objectClass: top
    cn: Sort sn givenname uid
    vlvSort: sn givenname uid
    ^D
  3. To modify a browsing index configuration, edit the corresponding vlvSearch entry or the corresponding vlvIndex entry.
  4. To remove a browsing index so that the browsing index is no longer maintained by the server, remove the individual vlvIndex entries.
    Alternatively, if only one vlvIndex entry exists, remove both the vlvSearch entry and the vlvIndex entry.
