Sun Java System Directory Server Enterprise Edition 6.3 Developer's Guide
Post-Operation Entry Access
Parameters for use with post-operation plug-ins follow. These parameters allow plug-ins to compare the state of an entry before an operation with the state of an entry after an operation.
Table 18–16 Post-Operation Entry Access Parameters
Parameter ID
Data Type
Description
SLAPI_ENTRY_PRE_OP
Slapi_Entry *
Directory entry before the operation.
SLAPI_ENTRY_POST_OP
Slapi_Entry *
Directory entry after the operation.
