NAME | Description | Attributes | See Also
Syntax |
integer |
Default value |
unlimited |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximum number of operations per connection that is allowed by the associated connection handlers.
This property takes an integer.
The value of this property must be at least 1.
The default behavior for this property is as follows: No limit
This property is used to configure the following features:
Resource limit policies define the maximum resources that Directory Proxy Server can process for a given connection handler.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
