NAME | Description | Attributes | See Also
Syntax |
integer |
Default value |
10 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the number of new connections that are created when the server needs more connections for read operations.
This property takes an integer.
The value of this property must be at least 1.
This property is used to configure the following features:
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
