Sun Cluster 3.0-3.1 With Sun StorEdge 9900 Series Storage Device Manual
ProcedureHow to Replace a Node-to-Switch Component in a Cluster That Uses Multipathing
  1. Is your configuration active-passive?
    If yes, and the active path is the path that needs a component replaced, make that path passive.
  2. Replace the component.
    Refer to your hardware documentation for any component-specific instructions.
  3. (Optional) If your configuration is active-passive and you changed your configuration in Step 1, switch your original data path back to active.
