Sun Cluster 3.1 4/04 Release Notes for Solaris OS
Unable to Add Adapter to IPMP Group After Removal (4884060)
Problem Summary: If SunPlex Manager is used to remove an adapter from a multi-adapter IPMP group, it may not always be possible to immediately add the adapter back to the same group again.
Workaround: Remove /etc/hostname.adapter before attempting to add the adapter back to the same IPMP group.
