Problem Summary: The SunPlex Manager data service installation wizards for Apache and Oracle do not support Solaris 9 and above.
Workaround: Manually install Oracle on the cluster using, using Sun Cluster documentation. If installing Apache on Solaris 9 (or higher), manually add the Solaris Apache packages SUNWapchr and SUNWapchu before running the installation wizard.
