Sun Cluster 3.1 4/04 Release Notes for Solaris OS
Simple Root Disk Groups With VERITAS Volume Manager
Simple root disk groups are not supported as disk types with VERITAS Volume Manager on Sun Cluster software. As a result, if you perform the procedure “How to Restore a Non-Encapsulated root (/) File System (VERITAS Volume Manager)” in the Sun Cluster System Administration Guide for Solaris OS, you should ignore Step 9, which asks you to determine if the root disk group (rootdg) is on a single slice on the root disk. You would complete Step 1 through Step 8, skip Step 9, and proceed with Step 10 to the end of the procedure.
