In the Sun Cluster Data Service for Sun Java System Application Server Guide for Solaris OS, the example given for the asadmin command is incorrect and should be ignored. Step 15 of the procedure “How to Install and Configure the Sun Java System Application Server” should read as follows:
Change the location of the accesslog parameter to reflect the directory that you created in Step 11. To change this parameter, use the asadmin utility. See Sun Java System Application Server 7 Administration Guide for instructions.
