Problem Summary: If scsetup is used in an attempt to add the first adapter to a single-node cluster, the following error messsage results: Unable to determine transport type.
Workaround: Configure at least the first adapter manually:
# scconf -a -A trtype=type,name=nodename,node=nodename |
After the first adapter is configured, further use of scsetup to configure the interconnects works as expected.
