Sun Cluster 3.1 4/04 Release Notes for Solaris OS
HA-Siebel Does Not Automatically Restart Failed Siebel Components (4722288)
Problem Summary: Sun Cluster HA for Siebel does not monitor individual Siebel components. If the failure of a Siebel component is detected, only a warning message is logged in syslog.
Workaround: Restart the Siebel server resource group in which components are offline by using the command scswitch -R -h node -g resource_group.
