Sun Cluster Data Service for Network File System (NFS) Guide for Solaris OS
Sun Cluster Data Service for Network File System (NFS) Guide for Solaris OS explains how to install and configure SunTM Cluster HA for Network File System (NFS) on both SPARC® and x86 based systems.
Note –
In this document, the term “x86” refers to the Intel 32-bit family of microprocessor chips and compatible microprocessor chips made by AMD.
This document is intended for system administrators with extensive knowledge of Sun software and hardware. Do not use this document as a planning or presales guide. Before reading this document, you should have already determined your system requirements and purchased the appropriate equipment and software.
The instructions in this document assume knowledge of the SolarisTM Operating System and expertise with the volume manager software that is used with Sun Cluster.
Note –
Sun Cluster software runs on two platforms, SPARC and x86. The information in this document pertains to both platforms unless otherwise specified in a special chapter, section, note, bulleted item, figure, table, or example.
UNIX Commands
This document contains information about commands that are specific to installing and configuring Sun Cluster data services. The document does not contain comprehensive information about basic UNIX® commands and procedures, such as shutting down the system, booting the system, and configuring devices. Information about basic UNIX commands and procedures is available from the following sources:
Typographic Conventions
The following table describes the typographic changes that are used in this book.
Table P–1 Typographic Conventions
Typeface or Symbol
 The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
 What you type, contrasted with onscreen computer output
machine_name% su
 Command-line placeholder: replace with a real name or value
The command to remove a file is rm filename.
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
These are called class options.
Do not save the file.
(Emphasis sometimes appears in bold online.)
Shell Prompts in Command Examples
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts
 C shell promptmachine_name%
 C shell superuser promptmachine_name#
 Bourne shell and Korn shell prompt$
 Bourne shell and Korn shell superuser prompt#
Related Documentation
Information about related Sun Cluster topics is available in the documentation that is listed in the following table. All Sun Cluster documentation is available at
Data service administration
Sun Cluster Data Services Planning and Administration Guide for Solaris OS
Individual data service guides
Sun Cluster Concepts Guide for Solaris OS
Sun Cluster Overview for Solaris OS
Software installation
Sun Cluster Software Installation Guide for Solaris OS
System administration
Sun Cluster System Administration Guide for Solaris OS
Hardware administration
Sun Cluster 3.x Hardware Administration Manual for Solaris OS
Individual hardware administration guides
Data service development
Sun Cluster Data Services Developer's Guide for Solaris OS
Error messages
Sun Cluster Error Messages Guide for Solaris OS
Command and function reference
Sun Cluster Reference Manual for Solaris OS
For a complete list of Sun Cluster documentation, see the release notes for your release of Sun Cluster at
Related Third-Party Web Site References
Third-party URLs that are referenced in this document provide additional related information.
Note –
Sun is not responsible for the availability of third-party web sites mentioned in this document. Sun does not endorse and is not responsible or liable for any content, advertising, products, or other materials that are available on or through such sites or resources. Sun will not be responsible or liable for any actual or alleged damage or loss caused or alleged to be caused by or in connection with use of or reliance on any such content, goods, or services that are available on or through such sites or resources.
Accessing Sun Documentation Online
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the archive or search for a specific book title or subject. The URL is
Ordering Sun Documentation
Sun Microsystems offers select product documentation in print. For a list of documents and how to order them, see “Buy printed documentation” at
If you have problems installing or using Sun Cluster, contact your service provider and provide the following information:
Use the following commands to gather information about each node on your system for your service provider.
prtconf -v
Displays the size of the system memory and reports information about peripheral devices
psrinfo -v
Displays information about processors
showrev –p
Reports which patches are installed
SPARC: prtdiag -v
Displays system diagnostic information
scinstall -pv
Displays Sun Cluster release and package version information
Also have available the contents of the /var/adm/messages file.
