Mounting/Dismounting a DG Cartridge on a drive
Command: Maintenance > Diagnostics
You can test whether a drive can mount or dismount a cartridge from a CAP cell or diagnostic cartridge cell
Note: For all diagnostic tests on a drive, use a diagnostic cartridge as these tests will destroy all the data on the cartridge. A diagnostic cartridge is a data cartridge with a "DG" label, which is used for diagnostic routines.
1. Click Mount.
2. Select the Drive ID from the pull down menu.
3. Click Start.
4. Enter your library password and click OK.
1. Click Dismount.
3. Click Start.
Note: This diagnostic test is available only on Lxxx libraries.
