Sun Cluster Data Service for Oracle Guide for Solaris OS
Appendix B Preset Actions for Database Management System (DBMS) Errors and Logged Alerts
Preset actions for DBMS errors and logged alerts are listed as follows:
Table B–1 Preset Actions for DBMS Errors
Error Number
Action
Connection State
New State
Message
18
NONE
co
di
Max. number of DBMS sessions exceeded
20
NONE
co
di
Max. number of DBMS processes exceeded
28
NONE
on
di
Session killed by DBA, will reconnect
50
SWITCH
di
O/S error occurred while obtaining an enqueue. See o/s error.
51
NONE
di
timeout occurred while waiting for resource
55
NONE
maximum number of DML locks in DBMS exceeded
62
STOP
di
Need to set DML_LOCKS in init.ora file to value other than 0
107
RESTART
di
failed to connect to ORACLE listener process
257
NONE
di
archiver error. Connect internal only, until freed.
290
SWITCH
di
Operating system archival error occurred. Check alert log.
447
SWITCH
di
fatal error in background process
448
RESTART
di
normal completion of background process
449
RESTART
di
background process `%s' unexpectedly terminated with error %s
470
SWITCH
di
Oracle background process died
471
SWITCH
di
472
SWITCH
di
473
SWITCH
di
474
RESTART
di
SMON died, warm start required
475
SWITCH
di
476
SWITCH
di
477
SWITCH
di
480
RESTART
di
LCK* process terminated with error
481
RESTART
di
LMON process terminated with error
482
RESTART
di
LMD* process terminated with error
602
SWITCH
di
internal programming exception
604
NONE
on
di
Recursive error
705
RESTART
di
inconsistent state during start up
942
NONE
on
Warning - V$SYSSTAT not accessible - check grant on V_$SYSSTAT
1001
NONE
on
di
Lost connection to database
1002
NONE
on
Internal error in HA-DBMS Oracle
1003
NONE
on
di
Resetting database connection
1012
NONE
on
di
Not logged on
1012
RESTART
di
co
Not logged on
1014
NONE
ORACLE shutdown in progress
1017
STOP
Please correct login information in HA-DBMS Oracle database configuration
1031
NONE
on
Insufficient privileges to perform DBMS operations - check Oracle user privileges
1033
NONE
co
co
Oracle is in the shutdown or initialization process
1033
NONE
di
1034
RESTART
co
co
Oracle is not available
1034
RESTART
di
co
1034
NONE
on
di
1035
RESTART
co
co
Access restricted - restarting database to reset
1041
NONE
on
di
1041
NONE
di
co
1045
NONE
co
Fault monitor user lacks CREATE SESSION privilege logon denied.
1046
RESTART
di
cannot acquire space to extend context area
1050
RESTART
di
cannot acquire space to open context area
1053
SWITCH
user storage address cannot be read or written
1054
SWITCH
1075
NONE
co
on
Already logged on
1089
NONE
on
di
immediate shutdown in progresss
1089
NONE
Investigate! Could be hanging!
1090
NONE
di
shutdown in progress - connection is not permitted
1092
NONE
di
ORACLE instance terminated. Disconnection forced
1513
SWITCH
invalid current time returned by operating system
1542
NONE
on
table space is off-line - please correct!
1552
NONE
on
rollback segment is off-line - please correct!
1950
NONE
on
2701
STOP
HA-DBMS Oracle error - ORACLE_HOME did not get set!
2703
RESTART
di
2704
RESTART
di
2709
RESTART
di
2710
RESTART
di
2719
RESTART
di
2721
RESTART
2726
STOP
Could not locate ORACLE executables - check ORACLE_HOME setting
2735
RESTART
osnfpm: cannot create shared memory segment
2811
SWITCH
Unable to attach shared memory segment
2839
SWITCH
Sync of blocks to disk failed.
2840
SWITCH
2846
SWITCH
2847
SWITCH
2849
SWITCH
2842
RESTART
Client unable to fork a server - Out of memory
3113
RESTART
co
di
lost connection
3113
NONE
on
di
lost connection
3113
NONE
di
di
lost connection
3114
NONE
co
Not connected?
4030
RESTART
4032
RESTART
4100
RESTART
communication area cannot be allocated insufficient memory
6108
STOP
co
Can't connect to remote database - make sure SQL*Net server is up
6114
STOP
co
Can't connect to remote database - check SQL*Net configuration
7205
SWITCH
di
7206
SWITCH
di
7208
SWITCH
di
7210
SWITCH
di
7211
SWITCH
di
7212
SWITCH
di
7213
SWITCH
di
7214
SWITCH
di
7215
SWITCH
di
7216
SWITCH
di
7218
SWITCH
di
7219
RESTART
slspool: unable to allocate spooler argument buffer.
7223
RESTART
slspool: fork error, unable to spawn spool process. - Resource limit reached
7224
SWITCH
7229
SWITCH
7232
SWITCH
7234
SWITCH
7238
SWITCH
slemcl: close error.
7250
RESTART
7251
RESTART
7252
RESTART
7253
RESTART
7258
RESTART
7259
RESTART
7263
SWITCH
7269
SWITCH
7279
SWITCH
7280
RESTART
7296
SWITCH
7297
SWITCH
7306
RESTART
7310
SWITCH
7315
SWITCH
7321
SWITCH
7322
SWITCH
7324
RESTART
7325
RESTART
7351
SWITCH
7361
RESTART
7404
SWITCH
7414
RESTART
7415
RESTART
7417
SWITCH
7418
SWITCH
7419
SWITCH
7430
SWITCH
7455
SWITCH
7456
SWITCH
7466
SWITCH
7470
SWITCH
7475
SWITCH
7476
SWITCH
7477
SWITCH
7478
SWITCH
7479
SWITCH
7481
SWITCH
9706
SWITCH
9716
SWITCH
9718
RESTART
9740
SWITCH
9748
SWITCH
9747
RESTART
9749
RESTART
9751
RESTART
9755
RESTART
9757
RESTART
9756
SWITCH
9758
SWITCH
9761
RESTART
9765
RESTART
9779
RESTART
9829
RESTART
9831
SWITCH
9834
SWITCH
9836
SWITCH
9838
SWITCH
9837
RESTART
9844
RESTART
9845
RESTART
9846
RESTART
9847
RESTART
9853
SWITCH
9854
SWITCH
9856
RESTART
9874
SWITCH
9876
SWITCH
9877
RESTART
9878
RESTART
9879
RESTART
9885
RESTART
9888
RESTART
9894
RESTART
9909
RESTART
9912
RESTART
9913
RESTART
9919
SWITCH
9943
RESTART
9947
RESTART
9948
SWITCH
9949
SWITCH
9950
SWITCH
12505
STOP
TNS:listener could not resolve SID given in connect descriptor.Check listener configuration file.
12541
STOP
TNS:no listener. Please verify connect_string property, listener and TNSconfiguration.
12545
STOP
Please check HA-Oracle parameters. Connect failed because target host or object does not exist
27100
STOP
Shared memory realm already exists
Table B–2 Preset Actions for Logged Alerts
Alert String
Action
Connection State
New State
Message
ORA-07265
SWITCH
di
Semaphore access problem
found dead multi-threaded server
NONE
Warning: Multi-threaded Oracle server process died (restarted automatically)
found dead dispatcher
NONE
Warning: Oracle dispatcher process died (restarted automatically)
