Sun Cluster Data Service for SWIFTAlliance Gateway Guide for Solaris OS
Planning the Sun Cluster HA for SWIFTAlliance Gateway Installation and Configuration
This section contains the information that you need to plan your Sun Cluster HA for SWIFTAlliance Gateway installation and configuration.
Note –
Before you begin, consult your SWIFTAlliance Gateway documentation for configuration restrictions and requirements that are not imposed by Sun Cluster software. For information about restrictions that the Sun Cluster software imposes, see the Sun Cluster documentation.
Configuration Restrictions
The configuration restrictions in this section apply only to Sun Cluster HA for SWIFTAlliance Gateway.
Caution – Caution –
If your data service configuration does not conform to these restrictions, the data service configuration might not be supported.
For restrictions that apply to all data services, see Sun Cluster 3.1 9/04 Release Notes for Solaris OS.
Configuration Requirements
The configuration requirements in this section apply only to Sun Cluster HA for SWIFTAlliance Gateway.
Caution – Caution –
If your data service configuration does not satisfy these requirements, the data service configuration might not be supported.
For requirements that apply to all data services, see “Configuration Guidelines for Sun Cluster Data Services” in Sun Cluster Data Services Planning and Administration Guide for Solaris OS.
Configuration Considerations
The configuration considerations in the subsections that follow affect the installation and configuration of Sun Cluster HA for SWIFTAlliance Gateway.
Resource Dependencies
Configure Sun Cluster HA for SWIFTAlliance Gateway to protect a Sun Cluster instance and its respective components. The following table outlines these components and their dependencies.
Table 1–3 Sun Cluster Components
Component
Dependencies
This component includes the SWIFTNet Link instance.
  • SUNW.LogicalHost resource
  • SUNW.HAStoragePlus resource
  • SUNW.scsag resource
Configuration Files and Registration Script
The Sun Cluster component has two configuration files and a registration script.
/opt/SUNWscsag/etc/settings.sh
This configuration file contains settings to enable the data service to find the correct instance of SWIFTAlliance Gateway and the necessary user and password combination.
/opt/SUNWscsag/util/sag_config
This configuration file contains settings to register the data service and the application in the Sun Cluster framework.
/opt/SUNWscsag/util/sag_register
This registration script enables you to register the data service.
Configuration Planning Questions
Use the questions in this section to plan the installation and configuration of Sun Cluster HA for SWIFTAlliance Gateway. Write the answers to these questions in the space that is provided on the data service worksheets in “Configuration Worksheets” in Sun Cluster 3.1 Data Service Planning and Administration Guide.
