Sun Cluster Data Services Planning and Administration Guide for Solaris OS
Example 1 – Migrating an Existing Resource to a New Resource Type Version
This example shows the migration of an existing resource to a new resource type version. Note that the new resource type package contains methods located in new paths. Because the methods will not be overwritten during the installation, the resource does not need to be disabled until after the upgraded resource type is installed.
This examples assumes the following.
(Install the new package on all nodes according to vendor's directions.)
# scrgadm -a -t myrt -f /opt/XYZmyrt/etc/XYZ.myrt
# scswitch -n -j myresource
# scrgadm -c -j myresource -y Type_version=2.0
# scswitch -e -j myresource
