Sun Cluster Data Services Planning and Administration Guide for Solaris OS
Information for Migrating Existing Instances of the Resource Type
The information that you need to migrate an instance of a preregistered resource type is as follows:
Example 2–2 Migrating a Logical Hostname Resource
This example shows the command for migrating the logical hostname resource lhostrs. As a result of the migration, the resource is modified to bypass name services for name resolution.
# scrgadm -c -j lhostrs -y Type_version=2 -x CheckNameService=false
